Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The keypad on the side of the garage is non responsive to any type of typing. I changed the battery and the keypad is not working, what do I need to do to get it working rcross388@comcast.net
    President:
  • 3,197 Answers
It sounds like your keypad has just failed. I think a new one is in order.
Posted on Sep 14, 2010
Hope you can suggest a solution to my problem with the 976LM Security Keypad. I did not work so assuming the battery needed to be replaced I inserted a new battery. But there is not life in the keypad....
It is never necessary to change the access code due to non use. It is the opener that remembers the code not the keypad. If the keypad doesn't even light up when you key in the code and press enter and you are certain the battery is good then the keypad has just failed and will need to be replaced.
Feb 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
Mounted keypad will not open garage door when I enter the code
Make sure the battery is good. It isn't uncommon to get one that has been on the shelf for a long period. If you still have the same problem and your hand remotes work okay you keypad is bad.
Mar 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
No lighting of keypad or response toentering code
Sounds like your keypad has failed if you are sure the battery you put in was good.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Raynor Keypad does not work
There should be a small screw about 3 inches up from the bottom. Remove this screw and the cover should slide off.
Oct 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
No code for keypad
It depends on the type of operator and keyless you have. If they are are compatable, the battery is good in the keyless and there are no wires to the keyless:
1. Push (don't hold) the Smart button (on the back or right side of the operator looking from the back of the operator toward the garage door)
2. Within 40 seconds type in 4 digit code on keyless, push and hold enter 3 seconds
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
48 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
