Question about Mitsubishi VS-45607 45" Rear Projection Television
Hi, Vs-4561 MItsubishi rolling picture
HI, I have the same problem as you do with the mitsubishi vs-4561 and was wondering if you got it fixed or discovered a solution. From what I can see online its the filtering cap that does it (either c7001,c7014,c7026 or c7036) a comb filter to be exact. I would appreciate any more info though! Thanks!
Brianne
brianne_sheppard@hotmail.com
  • 927 Answers
Good Day, pleasehelptv;
Those caps may be the problem but try this:
VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING,VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
HOPE THIS WAS HELPFUL.
Good Luck, big IRISH.
Posted on Jul 31, 2008
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi mod. vs-5072 rolls how fix?
check for swollen capacitors- bad capacitors will cause the screen to roll. If the top of a capacitor even looks SLIGHTLY puffed up, replace it!
Dec 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
I am trying to remove the screen on my Mitsubishi VS-4561 rear projection tv to clean it, how do I remove it? I know it slides up, anyone have a manual???
For my VS-45607 I had to first take off the speaker grill. Then there is a panel just below the screen that can be removed with screws; I removed this just for wire clearance. Then there are a few screws that are along the bottom of the screen that you take off and you should be able to slide the screen up and off. Good luck.
Dec 02, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-60603 lamp replacement
the VS 60603 has picture tubes three of them called CRTs you can get replacements at the following link.
http://servicemanuals.vstore.ca/
Aug 17, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
