Question about OKI C5400tn Laser Printer
Okidata 6150 printer says: "918:Fatal Error" upon startup - but only when I power it up with the duplex unit installed. What's the problem with the duplexer?
  • 11 Answers
SOURCE: Reset Duplex Unit Correctly on Ricoh 2232C
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Posted on Jan 31, 2009
  • 44 Answers
SOURCE: okidata c5200n printer 173:FATAL ERROR. What is
In the fuser unit the Heat roller thermister indicates a low temperature error. Replacing the fuser unit will usually resolve this. Fuser units are consumable items bur for an early life failure such as this it may be worth contacting the manufacturer.
Posted on Apr 19, 2009
  • 214 Answers
SOURCE: c5100 okidata printer w/duplex but still can't
You need to set installable options to duplex in your print dialogue box- or prefs somewhere. This is a setting up error
Posted on Apr 25, 2009
Kevin Hayes
  • 167 Answers
SOURCE: my printer keeps saying the duplex unit is not attached
The duplex unit is an OPTIONAL component on that printer.
Posted on Apr 29, 2009
Testimonial: "it was helpful but i need something a little more in depth"
  • 16 Answers
SOURCE: it won't duplex and when I go to advanced to trun it on it is grayed out
If your printer doesn't have 5650d (d for duplexing) then your printer doesn't duplex
Posted on May 11, 2009
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
Okidata C7300 Fatal Error 120
Service call 120: error
PU unit fan motor
1. Is fan in PU operating?
NO - Replace Fan motor.
YES - Replace engine control board (K7N).
2. Error reoccurs after replacing fan motor.
Jan 18, 2011 | OKI C7300 Led Printer
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 08, 2010 | OKI C9600hdn Laser Printer
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
I just replaced the fuser unit in my Okidata 5200 and it will print for awhile and then stop with a fatal error #177. How do I fix this?
lift your top cover up and check the ribbon cables to the black leds (4) under the cover 2 on each led, these have been known to be loose and cause those fatal error codes
Jul 09, 2009 | Office Equipment & Supplies
Okidata C7500 Little part broke on the duplex tray. Won't Duplex
You will probably save money by purchasing a new duplexing unit online.
Jun 03, 2009 | Office Equipment & Supplies
Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Apr 15, 2009 | Office Equipment & Supplies
C5100 okidata printer w/duplex but still can't print 2sided
Apr 14, 2009 | OKI C5100n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Okidata c5200n printer 173:FATAL ERROR. What is this? How do I fix it?
Mar 11, 2009 | OKI C5200n Laser Printer
OKI C5400tn Laser Printer Logo
397 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
