Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a Whirlpool refrigerator with the ice maker inside the freezer. It does make ice, but a lot of the ice bubes are either hollow or partly formed. I took the filter off completely and it not help. Any suggestions.
    President:
  • 1,218 Answers
Good day,
Sounds like your not getting enough water on the fill cycle.
Unlike a washing machine, you have 7 seconds for a fill cycle to complete. Period.
It's either the water valve on the bottom rear of the machine not opening completely and must be replaced since it's a non-repairable item, or the house water supply system is corroding and slowing the water down.
Posted on Sep 14, 2010
Maytag psd245ogr refrigerator, no water, no ice. Started with hollow cubes and over time smaller and less cubes. Finally, no ice in freezer and no water or ice at the door dispenser.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Maytag MSD2454G Side by Side Refrigerator
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
ICE MAKER ONLY MAKES HOLLOW ICE
Hollow ice is usually caused by not having enough water in the mold. A strainer before the inlet valve where the water supply connects can get stopped up restricting flow.
Or look for an adjustment behind the plastic endcover on the ice maker with a +/- on it. - is less water.
Sep 21, 2009 | Whirlpool ET1FHTXM Top Freezer...
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into fridge, ice maker making hollow ice
Make sure when the icemaker fills its not causing the leak ...... other than that you have a clogged drain in the freezer section .... easiest way remove everything unplug for 24 hrs with door open .... manual defrost ....hehehe ..... plug back in u should be ok if reoccurs call for service
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
THIN OR HOLLOW ICE
Freezer too cold and not much water. When it is empty of ice check the water level in the ice tray. Probably not even halfway up. Unplug fridge for 8 hours and plug it back in. Need more help please live chat. If this has helped, please rate as fixya.
Nov 19, 2008 | Whirlpool Gold Series GI15NDXT 15"...
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
