Question about Haier Energy Star ESA3183 Air Conditioner
My Haier air conditioner keeps coming up with an E17 error ??? Any Ideas
SOURCE: I have an E8 error message on my Haier hwr10xc6 Thru-Wall/Window Air Conditioner
Hmm E-8 don't now that one...Duz it still run at all..??? would check for build up on inside coils,,, and is small capillary tube "thermostat" in little plastic bracket and not kinked or touching the coils inside under the filter screen"evaporator"? did unit drain ok outside slightly lower than level ??
Posted on Jul 25, 2008
SOURCE: My Haier 5,200-BTU Window Air Conditioner keeps freezing up.
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Posted on Sep 24, 2008
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
SOURCE: Leaking Haier Commercial Cool air conditioner.
there are 3 drain holes in the primary pan right underneath the evaporator that need to be clean with a pipe cleaner or a wire of somekind and there is also a secondary drain behind it that will work only if the unit is 100% level. To access the primary drain pan you have to take all the screws of the back cover 5 on each side and 3 in the center above the electric cord and behind the air filter and only then will you be able to see these very small holes. Use a flashlight to make sure. Have fun!Reply
Posted on Jul 07, 2010
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
Won't turn on f1 in display
Your question has come up several times recently. But, due to the fact that Haier does not include what the Error Codes mean in their Owner's Manual. The only way to find out is contact Haier's Consumer Support Hotline 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Jul 22, 2011 | Haier HWR08XC7 Air Conditioner
The AC is on. Set at 61 deg. Keeps going back up to 81 deg. Blows cold for only 3 min. Any ideas?
You can try unpluging it to reset it .. this is a tough one as i not to certain.. But try that wait for about a munite nbefore you plug it back in.
Jul 19, 2011 | Haier ESA3109 WallWindow Air Conditioner
I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
Jul 23, 2010 | Haier Energy Star ESA3183 Air Conditioner
Getting an e1 code after the power went out is my ac just shot, its the haier hwr08xc7 any ideas
getting an e1 code after the power went out is my ac just shot, its the haier hwr08xc7 any ideas
Aug 20, 2009 | Haier HWR08XC7 Air Conditioner
I recently purchased a haier hwr08xc7 air conditioner within the last month. I get an E1 error on the digital screen readout and it wont run at all. It seems to keep kicking the relay built into the plug...
hello customer,
The temporary solution is to Power it ON using the remote contoller o thr air conditioner.It works.However i recommend you to lodge a service complaint to your dealer so that they would see to it.
Thank You.
Jul 09, 2008 | Haier Heating & Cooling
Haier air conditoner issue
E1 is a failed keystroke error for a haier air conditioner. Take it back, its essentially fried.
Jun 09, 2008 | Haier hwr10xc6 Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
281 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
