Question about Dryers
My dryer will not heat up i have change everything that has to do with the dryer heating up can u please me. thank u.
If a 220 service with cir breaker (s),turn both 110 breakers off and back on.i have had 1 breaker go bad.the dryer will run but not heat
Posted on Sep 14, 2010
Samsung heating elements dv206aes (dc47-00019a part). i would to know the step by step on how to replace my dryer heating elements. thank you. pam
Hi
Please check the bellow links to get the step by step instructions to replace heating element in your dryer:-
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
http://www.wikihow.com/Change-the-Heating-Element-in-a-Dryer
http://www.ehow.com/how_4819467_replace-dryer-heating-element.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 01, 2011 | Dryers
I have a LEN3434AWO Whirlpool dryer. Everything is working fine except there is no heat. Please help! Thanks!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 23, 2010 | Whirlpool GEW9250 Electric Dryer
Problem with the dryer not heating up?
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 03, 2010 | LG DLG5988 Gas Dryer
Gas dryer - kenmore 110.73932102
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 02, 2009 | Frigidaire FDE336RE Dryer
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
No Heat on Kenmore Gas Dryer Model 417
Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
Thanks
Vic
May 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Drum turns...no heat
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 19, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer will not heat to dry clothes
please rate me
Apr 19, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer not heating
most likely heating eleament change you can find here as well as diagram http://www.partstap.com/ please rate me thank you for useing fixya
Feb 25, 2009 | Dryers
Dryers Logo
Top Dryers Experts
