Question about Oster 76076-010 Hair Trimmer
The Clipper seems to pull the hair and does not cut smoothly. The machine gets very hot as you use it.
  • harvey pincus Sep 14, 2010
    Thank you.
    Where would I send the blades for sharpening or do I need to replace them? Are you talking about lubricating the blades and /or the machine as well?
  • 12,061 Answers
If a clipper is "Pulling" the hair, this means it is Blunt. The blades need to be sharpened, this too then causes the overheating as well as the machine must work harder to "Chew" through the hair instead of "Cutting" it. Also it should be lubricated more as well. It really is that simple. :)
Posted on Sep 13, 2010
Hi, I have a Braun series 3 shaver and sometimes
blades are blunt and the hair gets stuck between the clipper blade and the fixed blade
have them sharpened or replace with new one s
Nov 10, 2017 | Braun 380 Electric Shaver
How do you adjust the blades so that the hair won't get caught in the Oster 76097-440?
take off the clipper blade cover. 1 phielphs head screew. metal plate is about 11/2 ins. by 1" metal chrome cover. clean all hair out. your clipper came with a small plastic tube of oil. 1 or 2 drops no more put on cutter. any house hold oil will work
Aug 05, 2012 | Oster 76097-440
I have an A5 clipper, with three blades. I have had difficulty with this clipper, ever since I bought it. I have a schnauzer with very fine, soft hair, a bouvier, with very thick hair, and a Lakeland...
hi, on some ocassions when the clippers get hot the metal gear shaft moves meaning the movement of the clipper is limited, you can remove they gears in the gearbox when its hot and see if there is any side to side movement.
Nov 26, 2010 | Oster Golden A5 2-Speed Universal Motor...
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
My 78950-100 will not cut my dogs hair
The clipper that you purchase dose not have the power to cut the Dog fur, You need a Andis Xcel 2 speed with a # 10 clipper blade. www.mannyssharpening.com this clipper is quiet and has power. askmannyssharpening@yahoo.com
Feb 04, 2010 | Oster 78950-100
Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Apr 11, 2009 | Remington Health & Beauty
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Remington HC600 hair clipper stopped clipping
To all of you: adjusting the screws won't help, unless you screwed something up yourself, of course LOL The same problem bothered me a few years, and an hour ago I found out it could easily be a single hair stuck between the blades, thus separating them a bit. Get rid of it and the trimmer will probably work again. It can even get out spontaneously, which happened to me and kept me wondering what was going on.
P.S. DON'T lubricate unless you are required to (check your manual) The model I have (HC210c) does't need lubrication, I guess yours is similar to it. And remember that NOT every oily substance is a machine lubricant.
Jun 28, 2007 | Remington HC-600 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
244 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
