I have recently bought a samsung 750gb portable hard drive, everything was great I plugged it in and started to transfer videos onto it. After about 6~7 hrs the hard disc started making a constant clicking sound, can you confirm if this means the drive is snookered so I can return the item to the shop. Thanks
  • 328 Answers
Does it still make a clicking sound? If so, 2 reasons for this are: the USB or Firewire connection is faulty or yes, your hard drive is faulty. Try a different USB or Firewire port and see if it helps, otherwise return it for a new one. There is no need to keep one that you never know if and when it will fail. Good luck.
Posted on May 15, 2008
How to repower dead 2.5 disks
You can try taking them out of the cases and plugging it into an adapter. I use an adapter like this one myself for that kind of thing http://www.newegg.com/Product/Product.aspx?Item=9SIA5WW1XE5823&cm_re=hardrive_adapter-_-9SIA5WW1XE5823-_-Product
Aug 16, 2015 | Samsung M2 Portable 750GB 2.5" External...
My Samsung M2 PORTABLE 750GB USB20 HARD DRIVE giveing me message says thei is a write delayed
This happens when there is a disconnect of the usb interface or if the drive stops spinning. You either have a failing hard drive a failing usb enclosure or a usb issue with your computer. First thing is to plug the drive in to another computer to determine if this is a usb issue. If the problem persists then it is the circuitry in the enclosure or the hard drive. You may be able to install the drive into a new enclosure and if it works that was the problem, if not than you have a failing hard drive.
Jun 22, 2013 | Samsung M2 PORTABLE 320GB USB20 HARD DRIVE...
How can I transfer data between two primary hard drive after replacing one
Windows needs to be installed on the new primary hard drive and also thecomputer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Jul 09, 2012 | Toshiba Computers & Internet
During transfer some file,my portable hard drive failure.Then i remove safely before i put it again.The problem is,my portable hard drive asked me to format.What can i do without format?
get a copy of linux puppy and boot from cd while your external drive plugged in, it should recognise this under linux, then get what files you need and transfer to usb drive and reformatt the drive, I hope this helps
Feb 14, 2011 | Samsung HM251JI 250 GB SATA Hard Drive
My lacie external drive wont transfer my data from a mac to a pc
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Feb 13, 2010 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
My MacBook Pro no longer reads this portable hard drive. I have tried to plug it into a different MacBook Pro and the hard drive mounted onto the this laptop. I tried to transfer the files to a different...
at this point it sounds as though the drive itself is corrupted It is very difficult to try to get the data off once this happens and so there are data recovery places which charge into the thousands to do this.
Jan 21, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
HOW TO TRANSFER DATA FROM A DESKTOP TO AN EXTERNAL HARD DRIVE
I am guessing this is a USB hard drive. Is there a write protection on it? What are you trying to copy? You may have to limit the size of transfers and do multiple moves/copys. Or alternately you may use a backup program which may yeild better results depending on what you are trying to do, but also tends to be more consuming.
Jan 31, 2008 | Computers & Internet
Downloading music to a Samsung MP4 player
all you have to do is when the samsung window is open
plug in your portable player.
then left click on portable device
then on the lefthand side of the window leftclick my pc
then when you have selected the song that you want all you have to do is keep the left hand side of your mouse push down
and drag it to your portable device on the right hand side of your screen let go and walla it will load onto your mp3
when you want to transfer videos then all you have to do is on the lefthand side of your screen you will see a video sign click it with the lefthand side of your mouse key then you just click
and drag and it will load stright away.
just remember that videos take more time to load as they have more data to transfer.
Dec 28, 2007 | Samsung Yepp YP-T9 Digital Media Player
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
