Question about Garden
When I turn the key to start the **** Shortcut 1500, it only clicks. The battery appears to be built inside the mower and I don't see a quick, simple way of getting it out. Also, in case it is the starter, I need a manual that shows how to remove and replace. Please reply quickly, as my yard is in dire need. Thanks, Richard Jergins
THE BATTERY IS UNDER THE SEAT,TO GET IT OUT YOU HAVE TO TAKE OFF THE SIDE PANELS
Posted on Oct 04, 2010
  • crashumba395 Jul 24, 2011
    same exact problem , battery is charged, still just clicks when trying to start, thought it might be a sensor prohibiting the mower from starting, checked brakes and seat sensor both ok, would there be anything else proventing the starting of the mower? How can i check?
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Starter want turn
Starters burn up eventually, just had similar experience and I took the starter off to inspect and the magnets inside were broken off the wall of the starter and it would not turn. Age is a factor in most starters, these get hot being mounted on these small engines and don't last forever in most cases. Good Luck!
Oct 07, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
Ineed yahoo mail shortcut
www.yahoomail.com
To put a shortcut on your desktop
Method 1 loadTOCNode(3, 'moreinformation');
  1. Right-click an open area on the desktop, point to New, and then click Shortcut.
  2. Click Browse.
  3. Locate the program or file to which you want to create a shortcut, click the program or file, click Open, and then click Next.
  4. Type a name for the shortcut. If a Finish button appears at the bottom of the dialog box, click it. If a Next button appears at the bottom of the dialog box, click it, click the icon you want to use for the shortcut, and then click Finish.
Method 2 loadTOCNode(3, 'moreinformation');
  1. Click Start, point to Programs, and then right-click the program you want to create the shortcut to.
  2. Click Create Shortcut.
  3. The shortcut is now at the end of the Programs list. For example, if you created a shortcut to Microsoft Word, to find that program, click Start, and then point to Programs. You will find the shortcut, named "Microsoft Word (2)" (without the quotation marks), at the bottom of the Program list.
  4. Drag the shortcut to the Desktop.
Oct 12, 2011 | Yahoo Mail
Forgot user account psswords
If you have forgotten your password, if you have another user account with
administrative privileges you can log into that account and change your
original user account's password from the User Accounts applet in Control
Panel. If you don't have another account like this set up or don't have the
password to it, you'll need to log into the built-in Administrator account.
In XP Home, boot the computer into Safe Mode. Do this by repeatedly tapping
the F8 key as the computer is starting up. This will get you to the right
menu. Navigate using your Up arrow key; the mouse will not work here. Once
in Safe Mode, you will see the normally hidden Administrator account. The
default password is a blank.
In XP Pro, you do not need to go into Safe Mode. At the Welcome Screen, do
Ctrl-Alt-Del twice to get the classic Windows logon box. Type in
"Administrator" and whatever password you assigned when you set up Windows.
To change the built-in Administrator account in XP Pro if you can log into
another account with administrative privileges reset the password in the
Local Users and Groups snap-in in Microsoft Management Console (MMC):
1. Click Start, and then click Run.
2. In the Open box, type "mmc" (without the quotation marks), and then click
OK to start MMC.
3. Start the Local Users and Groups snap-in.
4. Under Console Root, expand "Local Users and Groups", and then click
Users.
5. In the right pane, right-click Administrator, and then click Set
Password.
6. Click Proceed in the message box that appears.
7. Type and confirm the new password in the appropriate boxes, and then
click OK.
If you reset the built-in Administrator account's password in Home or have
Pro and don't remember the password, use NTpasswd to change the built-in
Administrator account's password to a blank.
Sep 30, 2011 | Computers & Internet
I don't know how to get back my Microsoft word on my computer.
Hello, there are many posibilities your MS Word is still in your computer, If you have Windows XP click on Start menu then click on all programs, and look for Microsoft office folder, once you have your mouse over that menu, it will show all your MS Office applications, to get back your MS Word icon to the desktop, right click on Microsoft Word's icon and then click on Send to, then click on Desktop (Create A Shortcut).
Almost the same procedure is used with windows Vista/Seven: Click on start menu and type in the search box the word: 'Word', you'll see all the matches, there must be MS Word among the matches, right click on it and send the icon to desktop as a shortcut.
If you don't find The office folder nor the word Icon, is time to 'restore' your system, on Windows XP press F1 key and under the Choose a task subtitle, look for something like 'Undo previously done changes using System Restore', system restore window will appear, click on next and choose a date before the problem started happening, for example if the problem started on wednesday and your most recent restore point was on monday click on monday and start the restore process by clickng 'next' button.
The same procedure is very similar on Windows Vista and Seven, for these OSes you'll have to search for 'System Restore' in the F1 help menu and follow the instructions given.
If you're still having problems finding MS Word my recommendation is to go to a computer store and seek for professional help on the subject.
I hope these tips help, best wishes.
Have a nice day.
May 31, 2011 | Microsoft Computers & Internet
How do I turn off safe mode on Mozilla
Want to turn off Safe mode option on your Mozilla Firefox? Then follow this simple steps:
  1. Open Mozilla Firefox
  2. At the top of it (Firefox window), click on the Firefox button (in you have Windows Xp, click on File menu) and then click Exit.
  3. Start Firefox as you normally would.
  4. If Firefox keeps starting in Safe Mode see Firefox is stuck in Safe Mode.
If your Mozilla Browser is stuck on safe mode better to the steps here: Click here
May 16, 2011 | RCA VR702HF VCR
Turn on wireless
To turn the wireless on on your laptop:
1. Click on Start. Type Mobility in the Search box. Hit the enter key.
2. In the Search results under Programs you will see Windows Mobility Center. Click on it to open it.
3. You will see a button under "Turn Wireless On"
4. Click on it to enable your wireless.
Another way using a keyboard shortcut: Press the fn and F2 keys at the same time.
I hope this helps you-Thanks for using Fix Ya.
May 02, 2011 | HP Pavilion dv4000 Notebook
Systemax laptop not shutting completely down
Try this ;
Buried deep inside Windows XP lurks a little-known program called shutdown that shuts down your system in a very fast � but orderly � way. Here's how to put an icon on your desktop that'll shut down your machine quickly:
1. Right-click any empty location on your desktop.
2. Click New, Shortcut.
The Create Shortcut Wizard appears.
3. In the Type the Location of the Item box, type shutdown -s -t 0.
It's important that you put spaces before each hyphen, that you have no spaces after each hyphen, and that you use a zero at the end.
4. Click Next. 5. In the Type a Name for This Shortcut box, use a name that will remind you that this button is for a very quick shut down.
6. Click Finish.
Jan 15, 2009 | Systemax AOL Optimized PC (100607) PC...
Garden Logo
258 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
