Question about Honeywell Heating & Cooling
I have a pc8900 honeywell thermostat, and it died. The screen went black; however, this has happened before and it came back to life but this time it remained dead. What is the replacement for the pc8900 thermostat since it is out of production?
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
  • 3 Answers
SOURCE: Honeywell Thermostat power light
I just had this happen to me a few days ago. I hope you find this response before you did what I did and paid an AC guy $103 for him to do about 5 minutes worth of work. Here goes.
The power is shutting off because your drip line is clogged. Your drip line is the tubing that goes from your compressor (inside) to the outside of your house. When that tube gets clogged up (with algae and dirt) then the water will backup in the line. There is a protection circuit in the line and when it detects water (because of a backup) then it shuts all power to the AC off. If you take a shop vac outside and **** all the **** out then you'll be fine. The AC guy said that when I replace my filter every month that I need to pour about 1/2 cup of bleach in the line (from the inside) to prevent algae from forming and stopping the pipe up. Hope this helps someone out there before it costs them a $100.
Posted on Jun 11, 2009
  • 340 Answers
SOURCE: T8011 HONEYWELL THERMOSTAT TURNS OFF & ON
battier dead replace or their is a control wire problem check for loose connections. Tom
Posted on Jun 21, 2009
  • 118 Answers
SOURCE: Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Posted on Oct 28, 2009
Testimonial: "Thanks a lot for your help. I'll try that -- very simple!"
kingbrizzle
  • 407 Answers
SOURCE: honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Posted on Jan 23, 2010
Honeywell chronotherm iii died
did you check for correct positioning of new batteries ? also when but back on base is it securely attached?
Nov 19, 2013 | Heating & Cooling
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
My st6400c Honeywell programmer blank. Mains turned of whole day. Now back on, but st6400c blank.
Have you tried pressing the 'Reset' button (with the tip of a pencil)? After doing this, you will have to re-enter the various times. It could be that your rechargeable battery is nearing the end of its useful life, by the way.
George
Feb 23, 2011 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
My honeywell theromstat is stuck on HOLD 62 degrees and when I not turn on or go higher no matter how higher i push the heat
the honeywell theromstat is life time so no matter what happens you can call any hvac company and ask them it does sound like your batters are going dies are also you need to get your line check now i dont know if you have it on two wire are all four just maybe it could be that you need to get that look at
Dec 10, 2009 | Honeywell CT3200 5-2 Day Electronic...
I am attempting to turn on the home central gas heater for the first time this year. It is controlled by a honeywell self ignition model number sv9541. I follow the instructions on the front panel and...
Check to make sure the gas valve is opened. I've turned mine off for the summer months; when I went to use the heater for the first time...I realized I had turned the gas off.
Nov 17, 2009 | Honeywell Programmable Thermostat Heater
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
520 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
