Question about XFX GeForce 6200 Graphic Card
Blank screen So when the card is plugged in the screen goes blank. When it's not and the onboard video is used everything is fine. Went through BIOS, but no joy. I've swapped the card to a different computer and it worked fine, and I put a different card in my computer and that worked fine, but they wouldn't work together. The Geforce 6200 has a power plug on one end and by accident I left it undone while trying to fix it and then it worked. Here's my problem. I can't find anything about that plug anywhere. It works without the plug, but it's got to be there for a reason, and I'm worried that I won't be getting the full benifit of this card without it plugged in. But when it is plugged in it doesn't work. Does anyone know anything about this or why it is acting like this.
  • 1 more comment
  • Itbum May 15, 2008
    Additionally when the card is used it gives a message saying it needs additional power. Presumably because the power isn't plugged in. I'm assuming now that it's a damaged card, but if anyone knows anything else that could be wrong I'd appreciate the help.
    Not the fan plug. That is plugged in. There is an actual power connection that plugs into the power supply, or rather that the power supply plugs into. It's at the far end of the card from the monitor connection. When used without this plugged in a warning comes up saying that the card is underpowered and is stepping down its abilities. When plugged in it does nothing. The card is AGP and the comp is a cicero cq126a-b1
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Hi - if you're talking about the little white plug with a black and a red wire it's the power to the fan. If that's it you kinda need that. Don't want the chip fryin'. That wire plugs into a little white connector a little down and to the left of the fan. Only fits in one way. Is that a PCI-E card? What's the make and model # of the pc please? Thanks.
    Jeff
    Problem Solver:
  • 7 Answers
I just installed a geforce 6200 with heatsink, no fan, in my computer. Fry's is having a sale and for $20 after rebate, how could I go wrong? Upon first installation, the computer failed to boot.
THE FIX
Discovered modern computers will not even atempt to boot if the power supply is below the minimum requirement for the video card's recommended wattage. More proof that over-powered supplies are not an absolute necessity. I upgraded to 250w from the onboard 180w and it fired up. The rest was disabling the integrated video which i found out was compatible with geforce 5200 level of operations.
My system:
Dell Opti-plex GX260, cut to bare minimum since it was from a commercial business with 1G RAM after upgrade.
Posted on May 24, 2008
9500GT (PCI) card will not boot as stand alone card
make the changes to the bios before you put the card in and also install the drivers to your operating system then turn off pc fit card and let me know if it works
Feb 12, 2013 | Computers & Internet
Disable onboard video card on dx4870 ub318
enter your Bios then Advanced settings there should be an option to turn of onboard graphics or switch to pci..
Dec 27, 2012 | Gateway Computers & Internet
EV3A GT520 video card installation makes my screen go blank. My gateway computer has an integrated chip for video, and does not even recognize the new card but its plugged in, fan working, etc.
some bios settings disables the add on video cards. to enable them go to bios setting by pressing DEL or F12 while power on your system. (u will see that a message appears "press ----- Key to enter bios settings). after entering bios setting u will see onboard VGA enable/disable. u have to disable onboard VGA in order to get the display thruogh VGA card.
Sep 21, 2011 | Nvidia GeForce GT 520 1 GB DDR3 Video Card...
I have a asus p5g41-mlx3 mobo and i'm trying to install a palit 8400+ 1gb video card, but after installing and starting up my pc i get a blank screen. if i take out the card my computer works fine....
Check if it a jumper to disable the onboard video. If not, try disabling the onboard video in BIOS or selecting the option in BIOS to use a plugin card rather than onboard.
Where do you have your video cable plugged in? With the new graphics card installed, do you have video out of either connector?
Jim
Preston Computer Services
www.prestoncomputerservice.com
Jun 03, 2011 | Palit Microsystems GeForce 8400GS,, PCI...
Acer Aspire not going into POST
If it wont POST-then prbly hardware problem-inspect MOBO -disconnect all drives and try to boot into BIOS
Jan 30, 2010 | Acer Aspire T310 PC Desktop
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Monitor goes blank less than a second after turning on.
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
Windows doesn't load
Here's 2 things i would try:
1. Install the latest bios first:
click here
2. When you install the new card, go into the bios first and disable onboard graphics (seems like theres isn't an option for that unfortunately, but check again anyway) choose "auto" if you have no "disable" feature.
3. If you have another pc, or a friend with another pc i would test the card on a different pc just to make sure its not a faulty card.
Jan 17, 2008 | Jaton GeForce MX4000, (128 MB) PCI Graphic...
XFX GeForce 6200 Graphic Card Logo
119 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
