I am looking for an adjustable stand for my Viewsonic Monitor (Model #VS11349). It's just 1/2" too high for the height of the hutch on my computer desk. Can I get one from the manufacture or are there other sources?
  • 732 Answers
Lenphi, With two pieces of hardwood flooring (oak, walnut) ,raise ends of hutch and monitor should fit under it. Then continue looking for shorter or adjustable stand. Let me know in 2012 when you find one. Might be easier to find a "wall mount bracket kit" and then attach monitor to rear or one side of your hutch. Just a suggestion!!! 12fixlouie
Posted on Sep 14, 2010
Height adjustment on monitor stand is stuck. This stand is used on the Samsung SyncMaster 213T and the Dell 2001FP monitor.
I'd call or email samsung. They actually want to know about product problems so the next edition is an improvement. Their Owner's manual should have contact info, or the install cd or google. Tomshardware.com
always seems to be very helpful and may have a "fix".
Mar 13, 2015 | Samsung SyncMaster 213T 21.3" LCD Monitor
I have a dell 1908fp monitor And the silver rectangular button is stuck which stops me from adjusting the height on the monitor. How do I fix?
I didn't think this model had a height adjustment. Have you adjusted the height in the past? Maybe the silver button detaches the stand from the lcd screen.
Apr 18, 2012 | Dell Computers & Internet
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
How do I adjust the screen tilt and height? HELP!!!!!!
Hi, Here is what I was able to find out about your monitor from ViewSonic. There is no manual available on their website.
I have two ViewSonic monitors that are very similar to the one you have.
Here is what I can tell you. The monitor, although it does not seem like it can, be tilted front to back.
If you grip the monitor screen on the side edges (left and right) and 1/3rd the way up and twist it either away or toward you, it should tilt. It is a little stiff, just go ahead and tilt it. As far as adjusting the high. That, I'm sorry to say cannot be done.
I hope this helps you.
Best Regards,
Mark
Feb 15, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Instructions on how to disassemble and fix a Viewsonic VX2235WM
Here is a link to a repair guide that shows how to dis-assembly the unit and that what to look for any replace on the power supply board to repair most problems on the VX2235wm monitors. The repair guide has pictures and videos showing the procedures.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
May 19, 2010 | ViewSonic VX2235WM Monitor
Can I change the angle of my viewsonic screen
Here is what you can do ergonomically;
Height adjustment range 8.1cm / 3.2", tilt, swivel range 360º
So, yes you can tilt the monitor's angle, but if you are asking about the viewing angles then no you cannot.
May 09, 2010 | ViewSonic VA1930WM LCD Monitor
How do i adjust the stand so that the monitor is is not to low on the stand
Here's the manual for your monitor.
http://support.dell.com/support/edocs/monitors/E176FP/En/index.htm
If you got it with the stand it usually comes with, I'm afraid the height is not adjustable. The screen can tilt toward you and away from you, but that's all.
Sorry I don't have better news!
Mar 13, 2010 | Dell E176FP 17" LCD Monitor
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Jan 15, 2009 | Computers & Internet
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
