Question about Frigidaire FEF336BC Electric Kitchen Range
CIRCUIT BOARD It appears that the circuit board to my stove has exploded. It started to sizzle then blew up! All we did was turn the stove on. No history of previous problems. Is it cheaper to replace the board or get a new stove. Thanks!
  • 145 Answers
If your replacing it yourself The clock is under $100 if you have a service company replace it it may cost alot more.
Posted on May 15, 2008
Superba. Why won't stove and left front burner turn off completely?
Hello. You didn't provide the model number for your unit so my help is limited. From what you're describing, it sounds like the infinite switch(fancy name for burner control) has begun to fail(in a short-circuit type of manner). Be advised though, depending on the model of unit you have(such as the glass touch-panel type), the problem could be a damaged circuit board, either the main board or the user interface board. Also, if so equipped, there can be a relay board that EVERYTHING passes through which can have partial failures and produce the symptom you have. This relay board is typically mounted on the rear wall of the oven, under the rear cover. Did you have a power outage recently(such as 3-4 weeks prior to this happening)? Outages are notorious for damaging electronic controls--usually after that time period, the damaged chips start to fail, causing all sorts of problems. If I have the model number, I can provide part numbers and possibly, exploded diagrams.
Jun 25, 2015 | KitchenAid Kitchen Ranges
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
I have a 930 Bernina and it started to sizzle and smoke came out of it. It smelled real bad.
I repaired one last week for the same fault.
A component called a capacitor blew on the main circuit board. I was able to repair it but you may have to replace the entire board.
Expensive job but worth it as its a quality machine.
Mike
http://www.sewingmachineswales.com
Jul 10, 2011 | Bernina 1008
Whirlpool ee3z50rd055v stopped working after our power had been out for 5 days.
Have you checked your panel for a breaker that has the 2 switches tied with a black piece of plastic (I will attach a picture below...), if it is off, or in the middle (tripped position) turn it firmly to the off position, then back on. If your panel is labeled, look for the label that either says "Range" or "Stove"even if it is already on, turn it off and back on, If you hear any form of sizzling, or smell any odd/burning smells coming from the panel, turn that breaker back off right away, and call an Electrician, that is not something that you will be fixing yourself, it is way too dangerous., but after you check the breaker and it stays on with no issues, and the stove still doesent work, check that it is plugged in correctly, and not burned or loose. If that it is still not working, then I suggest that it is time to call a Licensed Electrician....
May 05, 2011 | Kitchen Ranges
None of the elements work, stove top or oven, stovetop light 'surface heating' will come on but nothing heats. Oven light on panel doesn't turn on but light in oven is off unless both dials are on or a...
Remove the panel on the top of the back of the stove - check for grease residue on connectors plugged into circuit board - clean connectors and circuit board with electrical contact cleaner - reassemble and test for correct operation. The oven vent at the rear of stove sometimes leaks grease filled vapors into the area of the control circuit board.causing bad or intermittent electrical connections to oven temp sensors and front controls on the oven.
Dec 22, 2017 | Kitchen Ranges
Harman P68 pellet stove glass fuse blows after 1 minute.
You can do some troubleshooting by looking at the glass fuse after it has failed. If the element looks melted and there is no other discoloration, then the fuse probably blew as a result of an overload somewhere. If the fuse is burned black, then it's probably a short in the system.
You can meter the motors to see if they are shorted anywhere or open.
It sounds like you may be correct about the circuit board.
Jan 02, 2010 | Kitchen Appliances - Others
My oven and stove top in inoperative. the clock,
If everything checks out fine, and you have no wires grounding out, then the issue is the control or circuit board( same thing).
Jan 02, 2010 | Frigidaire FEF366 Electric Kitchen Range
This time the oven
it sounds like it is the circuit board. i still use my mothers old viking stove, the old ones have none of these things that keep on braking.
Jul 22, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Blank Display on Electronic Oven Control
If the burners are working it is not the circuit breaker as both use the same circuit. The board does use the ground or neutral wire. I would check that and see if there is 12VAC supplied to the board. If there is then it would appear you have a fried board.
Eric
Jun 27, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Frigidaire FEF336BC Electric Kitchen Range Logo
140 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
