Question about Honda Karcher G2400HH-R Pressure Washer
We bought the pressure washer today. It is a used Quantum Gold 6.0 HP with a Briggs and Straton Motor. The motor works fine. When we tried the hose it had no pressure at all. The Model # 580752300 and Serial #1009224336. It did not come with a manual.
  • 174 Answers
SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
Posted on Jun 05, 2009
  • 1111 Answers
SOURCE: just bought a new Briggs Stratton 6 75 pressure
assuming you tried choking it when you tried to start it, verifiy its getting gas,if not tap lightly on the bowl of carburator. if it is getting gas, check for spark
Posted on Jun 20, 2009
brado83
  • 106 Answers
SOURCE: Pressure washer starts then shuts down in 2 seconds
hey mate,
It sounds like your bypass valve/unloader valve is sticking when pressure builds up in the lance,hose and head the pressure cleaner changes to a recirculate mode so it does not blow out hoses or seals or causes any damage to the unit, the bypass valve is the component that activates this sequence if that valve is stuck it will just try to continue to create pressure which in turn puts load on the engine and stalls it...
That is why it starts up straight away and only when it builds up pressure is when the engine stalls.
You would be best taking this to a qualified pressure cleaner technician as there are alot of little parts and orings plus the the head will need cleaning up and the bypass valve lubed, they may not of seen this at the service as it is hard to test a unit without the suited hose and lance... Often use will help this problem when a unit sits for a period of time that will cause issues such as this!!!
Regards
Brad:)
Posted on Sep 22, 2009
  • 5603 Answers
SOURCE: lose of pressure on Campbell washer
Usual cause is the pressure valve sticks closed and doesn't admit more water to be pumped. Usually needs new O RIngs and cleaning the bore... ABout a 15 minute job at most. Get an O Ring kit for it.
The valve is held shut when pressure on the output is high. When you open the trigger, the pressure drops and the valve opens letting more water come in from your garden hose.
The O RIngs dry out and bore gets dirty. Polish it with crocus cloth on a dowel rod. Lube the O Rings with lube intended for O RIngs.
Posted on May 08, 2010
Testimonial: "You hit the exact problem. After many discouraging information from repair people I got pump to repair in Springfield TN. He took back to shop - 10 minutes back with repair. Man what a releaf .. in a throw away, buy a new world. Thank you... you are great!"
SOURCE: shark pressure washer with honda 5.0hp motor when
what type pump oil to usefor karcher 2400 psi
Posted on Aug 06, 2011
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
Briggs and Straton OHV I/c 17.5 hp motor. Starter stays engaged. How do I touble shoot the starter or switch?
it sounds like the solenoid is staying engaged. try using a tester light on the starter.
Jul 15, 2011 | Garden
Hello i have a 6 hp briggs pressure washer and it starts fine and runs for 30 seconds and shuts off. it feels like the motor gets stuck when i try to start it again, but after a half hr or so it will turn...
You have to make sure you are pressing the trigger while you start the pressure washer. You should also make sure you are releasing the pressure at least every 30 seconds or the pressure will build in the pump and the engine can stall.
If it stalls with pressure in the pump and you don't relieve it by pressing the trigger, it will be very difficult to start. The pressure will slowly bleed off over time, which sounds like what you are seeing.
Jun 07, 2011 | Briggs & Stratton Gas Pressure Washer...
Must wait 30-40 mins to restart engine
Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
May 03, 2010 | Briggs & Stratton 3000 PSI Pressure Washer
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
Gas for 6.5 quantum
It's a four cycle, gas only. You only mix gas and oil on two cycle engines where there's no place to put oil such as trimmers and blowers.
Jun 17, 2009 | Garden
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
Honda Karcher G2400HH-R Pressure Washer Logo
337 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
