Question about Garden
I have a pto driven model # 25ptoc-17/A has some but very little voltage what could be the problem ? please contact me gkubesh@midrivers.com
  • 10,865 Answers
Hello. Your voltage regulator is bad. Replace it and you should be good to go. Joe
4 thumbs up please. ty.
Posted on Nov 05, 2010
  • 5,603 Answers
You may have to "flash" the rotating field as the residual magnetism may be too low to build up the field.
There is also a rectifier module that supplies the field current and that has a circuit breaker in it. Check that the circuit breaker is not tripped and the module is good.
Check the voltage applied to the field brushes by the rectifier with a voltmeter. There is a transformer in the circuit, but they are inherenly reliable.
Posted on Sep 13, 2010
How do gears to drive pto go in the manual transmission
If your transmission is PTO ready, there will be a plate on the side of the tans where the PTO bolts to it. The PTO will have a gear that goes into the transmission that is driven off of a gear on the input shaft. You will be able to engage and disengage the PTO by a slip gear in the PTO itself.
Nov 24, 2015 | Cars & Trucks
Battery won't charge and pto kills engine?
next I would try the stator underneath the fly wheel( the little copper coil wrapped plastic piece), then put the tester on the battery and see if it charges then
May 07, 2015 | Garden
My toro z4202 will not start it is not the battery as it is ok
First must sure you have both control arms are in neutral and the PTO switch is off. Depending on your model setup test for voltage at solenoid control terminal. If the voltage is present and your setup uses the separate solenoid check for voltage at each of the two large terminals while trying to crank there should be voltage on both of these if not then the internal contacts are burned and solenoid need replacing.
If no voltage at the solenoid control terminal then you need check the switches at the control arms, the PTO switch and the ignition switch.
The operator and service manual are available at the following link which contains the wiring diagrams.
Toro Z4202 (74381)
Dec 15, 2014 | Toro Garden
Ariens model 915111. Blades will not engage. Using a light voltage device. I placed the probe inside the socket which was connected to the pto clutch and it lit up. Can you tell me what part needs
If your receiving power at the PTO clutch and it is the correct voltage ie. 12vdc then you will need a new PTO clutch assembly.
Oct 28, 2014 | Garden
Pto switch will not work...it was replaced tnd it still will not work
check for voltage at pto if voltage there jump pto at the wire hub on pto if still pto dosnt come on bad new pto return it for new one and they get bad one it is a problem if good pto check voltage at pto should be 12.5 at least if not you got a bad stater 200.00 for it then install another 100.00
Aug 29, 2014 | Garden
PTO engages, but, keeps becoming disengaged on LT1042.
Cub Cadets have one of two types of PTOs. The most common is gear driven. The gear teeth of the PTO shaft are very small and thin. If the PTO is engaged without proper clutch action, the gear teeth grind together, trying to engage. A little wear on these gears will cause the surface of the gears to become beveled, and when the PTO comes under load, the beveled surfaces of the gear teeth force the gear lock to disengage. The only option is to replace the worn gears...
The second type of PTO drive is electric clutch. This is a disc type clutch that is engaged by energizing an electromagnet built into the clutch pack... any disruption of electrical power to the clutch pack while under load will cause the clutch to disengage and then possibly try to engage while under load and casues the clutch pack to slip and will overheat almost instantly...
Sep 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I just got a 5' KK rotary tiller and the pto shaft fits onto the tractor just fine with the button lock. The other end doesn't want to slide all the way onto the tiller gearbox drive shaft. It only goes...
http://www.youtube.cohttp://www.everythingattachments.com/Tractor
http://www.everythingattachments.com/Tractor-3-Point-Hitch-Tillers-Rotary-Tillers-s/76.htm
go to the second site first, it will explain your "problem.". Your problem is you need to adjust the length of the pto shaft to your particular application. not all pto shafts fit all attachments "out of the chute"
once the shaft is adjusted OR prio to modifying it, view the first video. both or very well presented. i've been there!
Happy tilling!!
steve wood
Rancho de Suenos
Albuquerque, NM
Mar 10, 2010 | King Kutter II Gear Driven Rotary Tiller...
1990 20hp Sunstar Rear PTO cuts out during rototilling operations, if I turn off switch and turn back on it will work for a little bit but then cuts out again. I recently replaced my engine with a 24hp...
Did you install the original electric clutch from the old engine?
If so, you may not have the adjustment right. On most electric clutches, there is a specific distance between the drive plate and the driven plate. Check your shop manual (if you have one) for this, as it does vary between manufacturers, and depending on the size of clutch.
Apr 17, 2009 | Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
