Question about Toshiba 42HPX95 42 in. Plasma Television
Toshiba 42hpx95 wont turn on.. when i unplug and plug in i can hear a sound but then a red light on the front starts blinking and it does nothing
TO ALL YOU TOSHIBA 42HPX95 I FOUND THE REAL PROBLEM ON THESE TV'S IM NOT SAYING THIS IS THE SOLUTION TO ALL TOSHIBA PROBLEMES BUT I GOT TOO OF THESE AND MANAGED TO REPAIRE THEM FOR ALMOST NOTHING "!!!!!' THE DEFECTIVE PCB IS THE SIRIEN PCB OR WHAT WE COULD CALL ACCESORY PCB THE PCB IS SHORT CREATING A OVER LOAD CONDITION AND THE PROTECT SYSTEM DOES ITS JOB I AM INCLUDING TWO PICTURES THE FIRST ONE WHATS THE ACCESORY PCB AND THE SECOND WHAT CONNECTER TO DISCONNECT IN THE SECONDARY SMPS WHAT YOU HAVE TO KNOW IS THAT YOUR PIP WILL PROBABLY NOT FONCTION ANY MORE YOUR PCCARD READER WITCH IS TOTALLY OUT OF DATE AND OUT OF DATE COMMUNICATION PROTOCOLS LIKE IEEE 1394
AND G-LINK AND MAYBE THE CARD READER ON THE SIDE IF NONE OF THESE ACCESSORYS ARE VIMPORTANT FOR YOU WELL YOUR TV IS FIXED IF THE ARE SIMPLY REPLACE PCB THE NUMBER OF THE PCB IS PD2266 I FOUND ONE FOE 120 DOLLARS AT SHOP JIMMY ALSO IF YOU MANAGE OUT WELL WITH A OHM METER HERES A TEST YOU CAN DO DISCONNECT TV FROM POWER DISCONNECT CONNECTER PJ63 ON ACCESSORY PCB WITC OHM METER TEST BETWEEN GROUND PIN 2 AND PIN 1 DO THIS ALSO WITH PIN 3 AND 4 THERE MUST BE NO CONTINUTY WITH GROUND ! HOPE THIS WILL HELPtoshiba 42hpx95 wont turn on.. when i unplug and - tombou300619.jpgtotoshiba 42hpx95 wont turn on.. when i unplug and - tombou300619_1.jpgclass=tombou300619_1.jpg
Posted on Nov 17, 2010
3 Suggested Answers
SOURCE: toshiba 42hpx95 wont turn on.. when i unplug and
toshiba 42hpx95 wont turn on.. when i unplug and plug in i can hear a sound but then a red light on the front starts blinking and it does nothing
Posted on Sep 13, 2010
SOURCE: Toshiba 42HPX95 wont turn on
I am having the exact same problem with my Toshiba 42HP95. From the information that I have been able to glean from the internet, it looks to be some sort of problem with the power supply or some other component of the power circuit. I am giving up and getting service
Posted on Jan 16, 2008
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
the blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Apr 29, 2010 | Toshiba 42HPX95 42 in. Plasma Television
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Power light blinking
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Sep 19, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
Dec 01, 2007 | Toshiba 42HPX95 42 in. Plasma Television
Tv will not turn on
The blinking red light is telling you that the set did not start up due to an overvoltage somewhere in the set. Most likely the main power supply has a fault like a bad regulator IC or a component associated with it, or there is a fault in the sweep power supply somewhere. if you have no electronic repair experience, play it safe and call out a tech to assist you with this repair. Good Luck.
Mar 19, 2007 | Toshiba 43H71 43" Rear Projection...
Tv will not turn on
it is a symtpom of vertical failure in circuit..its either loose connected part or blown up ic in vertical section but most of the time its just a dried up capacitors 100uf/50v 1000uf/25 and 2 2.2uf/50v
Mar 18, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba 42HPX95 42 in. Plasma Television Logo
605 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
