Question about Cyberhome CH-DVD 300 DVD Player
Player was put on progressive scan and has stop displaying any video
The player was accidentally placed on progressive scan and now no video displays whenever it is turned on. I had misplaced the manual so unable to rectify the matter.
  • tony ramirez
    tony ramirez May 26, 2008
    my dvd was also put on progressive scan my problem is i have a universal remote and dont know which button brings up the window to change it have tried all buttons
  • y_hammons Jul 01, 2008
    same
    Problem Solver:
  • 13 Answers
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Posted on Oct 27, 2008
    Genius:
  • Cyberhome Master
  • 1,550 Answers
Check on the control remote for that function and deactivate.
Posted on Jun 26, 2008
Does Magnavox mdv 2100/F7 dvd player have front panel display
Hello
This DVD player has no front panel display. Its front panel have ony two LED light indications, out of which, one is for power On indication and the other for p-scan [Progressive Scan] which will ight up when you select Progressive Scan function.
There are three push button switches, for Open/Close, Play & Stop.
It has only ON-Screen display system, which will be active only after connection the DVD player to tV. OK.
http://www.dataentryjobs.us/67948.html
Feb 02, 2012 | Magnavox Televison & Video
On the DVD player it is in the "progressive scan
Hi -
. Remove any disc from the unit and close the disc tray.
2. Wait for the "DISC message to appear on the display
3. Hold the "STOP" button on the front of the player for at least 5 seconds then release.
The video output should return to the normal setting and PSCAN should disappear from the display on the front of the player.
If you are still unable to switch P/SCAN off, please post back for further assistance.
Regards,
BElectric
Mar 29, 2011 | Zenith XBV443 DVD Player/VCR
Lost picture when set dvd player to progressive scan.
Hello Fearlessloki, Welcome to Fixya.
Would you mind posting some of the details on this DVD player that is having issues?
Jan 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Need to turn OFF progressive scan on Sony DVD DVP-NS57P
With the remote: While in STOP mode, press the DISPLAY button. Use up/down buttons to select SETUP. Press Enter. Use up/down buttons to select CUSTOM.Press Enter. Use up/down buttons to select SCREEN SETUP. Press Enter. Use up/down buttons to select PROGRESSIVE. Press Enter. The manual is a bit indistinct after this, but I think the prompts will direct you. Just turn Progressive OFF.
Owner's Manual page 61, link http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/DVPNS57P.pdf
Nov 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Split screen from DVD player, cable is fine no problem
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
Jan 07, 2008 | Televison & Video
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
No color when switching to component cable
To Change DVD Player Video Output to Progressive Scan: With your DVD Player turned on, and your TV turned on, press and hold the PREV/VIDEO button for at least 3 seconds (this puts you into Video Output mode). Press the PREV/VIDEO button to access different video output options. Each time you press
PREV/VIDEO, the type of video being displayed appears next to the Display menu. Look for PSCAN on your DVD player display panel. At this time, your progressive scan on TV should be working.
Oct 18, 2007 | RCA DRC233N DVD Player
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
GBV441 Goldstar DVD Player / VCR Combo
this is the right solution, the solution in the User Manual doesn't work
Nov 04, 2006 | Goldstar GBV241 DVD Player/VCR
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
126 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
