Question about Watches
Dont know hoe to set the coreect time and date
  • 831 Answers
Thank you for contacting FixYa.
ANALOG
  • Locate the knob on the side.
  • Pull the knob out. The second hand should stop ticking.
  • Twist the knob clockwise until the correct time is displayed on the watch face.
  • Push the knob back in, and the the second hand will resume ticking.
  • Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right sidePress the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your setting.
  • Best regards. Jewel
    Posted on Sep 14, 2010
    I have a new windy watch but dont know how to set the date and time on it could anyone please help me?????
    annoyingmist, let me try.
    1.by windy you mean mechanical?
    2. if yes, then move the hands clockwise watching the calender until new date appears.
    3. now turn hands anti- clockwise a little and clockwise again. Keep doing until you get today;s date.
    4. set the watch to correct time. good luck.
    Dec 25, 2013 | Watches
    I need to know how to set my skmei watch
    I need to change date and time for skmei 1065 pls help me ;)
    May 07, 2012 | Watches
    I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
    This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
    Dec 09, 2010 | Watches
    Dont know how to set date on an automatic watch
    mcdevito75, Here, You can set the date on your Timex Automatic, by simply slipping your fingernail just under the stem (winder) and gently lift it up to it"s first position (notch), this will allow you to turn the stem to change the date without haveing to turn the hands so many times. once set push the syem back in.
    Jun 20, 2010 | Timex Automatic Watch
    I dont know how to change the time? I have no
    to press left side upper button and right side butom button to set the time
    May 16, 2010 | Casio BabyG Shock Resistant Blue Sports...
    I have a screw down crown and dont know how to set the time, date etc
    I don't know the make of your watch but typical operation is described below. If the instructions are not correct, then some experimenting will sort out the correct functions- good luck!
    Unscrew the crown (anticlockwise) and pull it out.
    There are probably two "out" positions, the first one for date, forward(?) for date and backward(?) for day.
    The second position should be for time.
    Try this and check which
    Mar 01, 2010 | Watches
    Unable to set the date on an ESQ Gentlemen's Quest Big date
    pulling the stem to the first click adjusts the date and pulling it farther adjusts the time. pull the stem one click and turn counterclockwise to adjust date. push stem back in after correct date is displayed.
    Jan 05, 2009 | ESQ Quest 07100901 Wrist Watch
    How do i set the time
    The three buttons are the Chronograph start button (top), Crown (middle), and chronograph reset (bottom).
    To set the watch pull the crown out to the first position and turn it until it is on the right time.
    To set the date pull the crown out to the second position and rotate until you have the right date.
    Be sure that when you set the time that you are in the right AM or PM. DO this by watching when the date turns at the 12:00 position. The date changes at midnight so that would be AM.
    Aug 02, 2008 | Invicta 2191 Wrist Watch
    Setting the time
    There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
    Sep 23, 2007 | Rolex Daytona 116520 Wrist Watch
    Watches Logo
    139 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
