Question about Tatung V23DLWX Television
Can not program remote to TV
I have hooked up a RCA Digital box to a Tatung Tv M20CMG. I am trying to progam the remote( rcr312W) to the tv. The code that I have did not work and the instructions stated to contact this site to get a new code or to solve the problem.
Gary
  • 2 more comments
  • ajoellep Jun 19, 2008
    Trying to program an RCR312W remote to my old Magnavox TV and none of the codes will work.
  • hunterlawyer Jul 29, 2008
    I've an older SYLVANIA 19" color tv. The RCA site's codes are different than the manuals. Can't program. Pls help me!?!
  • Anonymous Aug 26, 2008
    i want the code
  • Anonymous Jan 26, 2009
    What happens if the stop button DOES NOT cause the On-Off button to turn off???
    Problem Solver:
  • 6 Answers
I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON DON'T JUST PRESS IT ONCE LIKE A LOT OF SITES SAY TO DO.  I HAD TO PRESS IT A FEW TIMES, AND THEN IT TURNED THE TV BACK ON AND THE REMOTE WORKED!!! MY REMOTE WAS THE RCA RCR312W...TV IS AN OLDER ORION
  1. TURN ON THE COMPONENT (THE TV, DVD, ETC)
  2. HOLD THE TV (OR DVD) BUTTON AND THE ON/OFF BUTTON AT THE SAME TIME.  IT WILL STAY LIT.
  3. PRESS THE PLAY BUTTON EVERY FIVE SECONDS until the component turns off.
  4. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  7. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  8. To save the new code, press and release the STOP button.
  9. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Posted on Jul 08, 2008
I was having trouble getting a Universal Remote to work with the ILO V23DLWX (26" LCD). Eventually I got it to work with a Logitech Harmony. Those remotes are programmed through USB on your computer, so Logitech is able to update their database with new models. The thing even controlled my air conditioner. You just put in the model number of the device and it does the rest. By the way iLO's are horrible and even if you can get a remote to work eventually the power supply will go and it is near impossible to reach a human at that company.
Posted on Jul 19, 2009
Need manual for rca rcr312w remote
Download the manual to your remote control by this link.
May 03, 2012 | RCA RCR312W Remote Control
I cant program my remote to my symphonic tv i need the codes
Hello
The remote codes for Symphonic TV with RCA RCR312W are
10180 & 10171
OK.
Jun 22, 2011 | RCA RCR312W Remote Control
CODE FOR RCR312W FOR MY APEX TV
Turn on the TV, Press and hold down the TV button while entering one of the four digit codes, if the ON/OFF turns off on the last digit entered, that's the correct code, if not, repeat steps, using a different code until it does..here are the codes,..1137,1141,1235.....hope this was helpful...
May 28, 2010 | RCA DIRECTV Satellite Remote Control
Lost RCA Universal Remote booklet for model RCR312W remote.
you need to supply the SONY TV model just do a google of any URC booklet and then look uo the ctrl codes for your TV it has little to do with the brand of the remote
please rate our help to keep service online
Aug 19, 2009 | Televison & Video
I need code for zenith tv to program into rca remote #rcr312w
Hi cuddles3634!
For that remote, the tv codes are:
Zenith 1000, 1006, 1049, 1054, 1078, 1116, 1133, 1167, 1170, 1172, 1207, 1230
If the TV is digital: 1016
Hope that helps!
Jan 04, 2009 | RCA Universal Remote Control
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Sep 10, 2008 | RCA Universal Remote Control
Rca rcr312w remote
i cant program any thing with my remote it is arca312w my tv is a emerson thanks
Sep 09, 2008 | Tatung V23DLWX Television
Tatung V23DLWX Television Logo
414 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
