Question about Sage Timeslips by 2006 Full Version for PC - 5 Pack
Is Timeslips 2006 compatible with Windows 7? - Sage Timeslips by 2006 Full Version for PC - 5 Pack
Tip
How To Diagnose Timeslips v9.0 and Higher
This feature is only available in Timeslips v9.0 (Service Release 11), v9.1, and higher. If you have a Service Release of Timeslips v9.0 lower than SR11, please download it from <a href="http://www.timeslips.com/Support/downloads"><b>http://www.timeslips.com/Support/downloads</b></a>. Be sure to install the update on each computer that has Timeslips installed.<br /> <p style="font-style: italic;"><br /><br /> <p style="font-style: italic;">If you have not already installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator. If you are using Timeslips v9.0, then you must reinstall SR11.<br /><br /><br /> <p>We recommend performing this procedure on every computer when you:<br /> <ul> <li>First install Timeslips</li> <li>Update Timeslips</li> <li>Update your computer's operating system</li> <li>Experience data corruption</li> <li>Experience errors starting Timeslips that tells you to use this feature</li></ul>Prior to performing the Diagnose This Computer procedure you must exit Timeslips as well as any other program which may access the Borland Database Engine (BDE). If you are unsure what programs may use BDE, close all other programs.<br /><a></a><b></b><br /><br /><a></a><b>Steps to perform the Diagnose This Computer procedure:</b><br /> <ol> <li>Close Timeslips and any other program that uses the Borland Database Engine (BDE).<br /><b>Note</b>: If you are unsure what programs may use BDE, close all other programs.</li> <li>Open Station Administrator on the computer you wish to diagnose.<br /><b>Note</b>: If you have not installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator.<br /><b>Note</b>: If Timeslips is operating in a network environment, and Station Administrator is not installed on the workstation, then use Windows Explorer to locate and run <b>Statadmn.exe</b> from the Timeslips installation folder on the server. [From the Windows Toolbar select <b>Start</b>; <b>Run</b>; <b>Browse</b> to locate and open <b>Statadmn.exe</b> from the Timeslips installation folder on the server.]</li> <li>In Station Administrator select <b>Options</b>; <b>Diagnose</b> <b>This</b> <b>Computer</b>. Click <b>OK</b> to confirm that all programs using Borland Database Engine are closed. Station Administrator will attempt to analyze your system.</li> <li>When <b>Analyze System</b> completes, the Diagnose This Computer dialog box will open and alert you to problems with your Timeslips database and operating system. Each of the four areas has an associated Fix button. If any Fix button is enabled, click it to either solve the problem or receive instructions for doing so. Click <b>Help</b> for further information.<br /><b>Note</b>: Even if no problems are reported, Station Administrator may make other necessary changes (<a href="http://kb.sagesoftwareonline.com/cgi-bin/sagesoftwareonline.cfg/php/enduser/popup_adp.php?p_faqid=14967&p_created=1122586187&p_sid=TUvWvcnk&p_lva=15461&p_li=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjE4LDIxOCZwX3Byb2RzPTUxMzQsNTE0MCZwX2NhdHM9JnBfcHY9Mi41MTQwJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*#does">see above</a>). </li> <li>If you have experiencing data corruption errors click <b>Change Operating System Settings</b> to open the Windows 95 and 98 Settings dialog box and unmark <b>Enable file system caching</b>. Click <b>OK</b> to return to the Diagnose This Computer dialog box. </li> <li>Click <b>Done</b>. If prompted to do so, restart your computer.</li></ol>
on Feb 21, 2011 | Computers & Internet
I need to install exceed powersuite 2006 version 11 on windows 7..which is compatible version??
Install it anyway... Tons drivers are not digitally signed. If that program is compatible with vista then more than likely it will work with windows 7 as well.
Jul 22, 2012 | Hummingbird Exceed PowerSuite 2006 Full...
Can Card Studio 2006 be used with Windows 7. Just upgraded computer from XP to Windows 7
That vesion is not compatible with VISTA so it isn't with Windows 7 either. Sorry
Jan 03, 2011 | Handmark Software Computers & Internet
My Timeslips Version 11 does not print the full bill template anymore, and so my firm name does not appear on the bill. It seems like there are other random changes that occurred after I refused to...
This is the Sage Timeslips support page. It may help answer your question. Good luck.
https://support.na.sage.com/selfservice/microsites/msbrowse.do?UMBrowseSelection=SG_SAGETIMESLIPS_1
Dec 02, 2017 | Timeslips 11 (TSW11RT) for PC
I use Timeslips version 2007. I want to email
CANT PRINT OUT CHECK USING VERSA GOLD 2008 ON WINDOWS XP AND PRINTER WONT READ ...........LEXMARK PRINTER IS WHAT I AM USING ANY HELP
May 12, 2009 | Timeslips Computers & Internet
Timeslips & Windows XP Services
well, hard to tell you which one you disabled that is needed, but I can tell you which ones are considered safe to disable, go to this article : http://www.cas411.com/ShowArticle.aspx?ID=82 and try to see if this list matches the ones you disabled.
Alex
Oct 17, 2007 | Timeslips 11 (TSW11RT) for PC
Sage Timeslips by 2006 Full Version for PC - 5 Pack Logo
761 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
ray gallant
richie46
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
