Question about Refrigerators
The compressor appears to have kicked out on the refrigerator
Have to get a new compresser
Posted on Sep 13, 2010
Maytag mod#MSD2550VEW00 compressor not kicking on
Could be the thermostat or defrost thermostat.
Oct 03, 2016 | Maytag Refrigerators
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
I have a Magic Chef Refridge MCBR 1010W that has stopped cooling, fan runs and you can hear it kick in but then kicks off? An Ideas?
If the compressor kicks in that tells you the compressor relay and board are probably good. HOWEVER, when you say it kicks off right away that is not a good indication! It sounds like a compressor problem. Is the compressor extremely hot or is the condenser coils icing up? If so, I wouldn't invest the money into repairing it, because it would cost more to repair than to replace.
Jun 16, 2011 | Magic Chef MCBR440 Compact Refrigerator
Compressor kicks on and then in a minute kicks off
grrtujytui Check the relay which is connected to the compressor first if the relay is not working it will cut-off the supply to the compressor.
May 10, 2011 | Kenmore Side by Side Refrigerator
My Kenmore 106.56573300 is not getting cold and is clicking.
sounds to me based on your description that you possibly have a bad relay on compressor. it is possible the compressor has failed due to a bad start relay and what you are hearing is the overload kicking out when trying to start.. you will have to remove the back cover from refrigerator and gain access once you gain access remove bottom cover and you will see compressor... you can get parts from several online appliance places... kenmore i would probley go to
www.sears.com then hit the parts direct link on the top of page
enter your model number and a parts diagram will appear go to compressor picture and pick the relay /start and overload give that a shot if it still clicks the compressor has failed and will need to be replaced // good luck to you
Jan 22, 2011 | Kenmore 53642 / 53644 Side by Side...
Our refrigerator wont kick on, no clicking or buzzing either. what do we do?
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Jan 16, 2011 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Fridge is kicking on but not cooling
If the compressor is "kicking on and off" while the unit itself continues to run, the compressor is failing to start, either due to the start relay / overload kit or the compressor itself is bad.
this is one part of the refrigerator I recommend you have a qualified refrigerator service test. If tested wrong, you could end up causing damage to compressor, turning an inexpensive repair into a new refrigerator purchase
Mar 28, 2010 | Refrigerators
Compressor not kicking in whirlpool refrigerator
Overload relays at the compressor have gone bad. Replace with new and you will be good to go. Hope this helps.
Feb 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
BARLEY COOLS COMPRESSOR WILL KICK ON AND RUN FOR 5 SECONDS AND KICK OFF EVERY COUPLE OF MIN THERE IS NOTHING ON THE COILS ANY IDEAS
Replace the compressor starter/overload relay. It's on or near the compressor. It will be making a click each time the compressor tries to start.
Nov 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
