Question about Cell Phones
In coming calls are fine = BUTon dialling out- the phone goes into speed dial mode; ending in an engaged/overload tone. There are no nos. programmed in phonebook or m1-m3. Also the LCD light doesn't turn itself off when plugged in. any suggestions other than bin it.? regards; Geraldine
  • 2 more comments
  • geraldine Sep 14, 2010
    Thanx Joe. Will follow your advice. G.
    Will know if the phone works properly after getting the "Factory reset" Thanks G.
  • geraldine Sep 15, 2010
    very helpful. After the "factory reset" it's working perfectly.
    Thanks for your comments. Fixed problem with a " factory reset" (something I never heard of till a couple of days ago) G.
  • 10,865 Answers
Hello. Your phone probably needs a factory reset. To have this done, take it to your local phone store. They will do a factory reset for free. J.
Posted on Sep 14, 2010
  • Cell Phones Expert
  • 2,973 Answers
Geraldine,
You do not have to bin the phone. Please go to settings. There in the call or phone settings you will find speed dial. Disable it. Regarding the lights being on during charging, some Nokia models do have their lights on during charging and there is no way that anyone can put them off. You have not mentioned what phone you are complaining about. Anyway, this is no cause for binning the phone.
What does a boken dialling tone on my phone mean? It is all working fine and there are no warning messages on the display.
Usually broken dial tone means the line has call-forward set. You get broken tone for 3 or 4 seconds, then goes back to normal. Are you receiving incoming calls normally? It's common to set or cancel 'cause the code might kinda match a number you use. And it may be forwarded to nowhere, example, you dial 729-1111, but press 72#-1111. You might be forwarded to 1111, the code being 72#. The 1111 goes nowhere, someone calls you, calls gets forwarded, then they get a message"that number does not exist". If that's the code for your area, then 73# might be the cancel code. Check the front of the original phone book, or Google codes for your service provider.
Jun 11, 2014 | Panasonic KX-TG4500 Phone
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Phone can receive calls but not make them.
hello i have a solution, you need to change you dialing mode on the base option, the deafult is "tone dialling", change to "pulse tone " this fix my problem on my A495 gigaset.
May 16, 2012 | Lands Phones
I cant figure out how to set up speed dial?
Go to your phone call settings and activate speed dials feature.
Then come back to your phone in normal display mode,press and hold any desired digit e.g 2,3,4,5,6,7 on the key pad and follow the prompt for assigning of phone nos for speed dialing.
Sep 14, 2009 | Lands Phones
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
We cannot make an indirect call using polycon soundstation2
it appears u have connected it to the epabx extension. when u try nos first & then press call, the unit dials the nos so fast that it does not understand ur access number (0 or 9) for dialling out.for this u need to give a pause between the access number ( 0 or 9 to get the dial tone for diallin an external no)this is available on the keypad as pause / redial & then out the number & press call.the prob should get fixed!
Sep 23, 2008 | Polycom SOUNDSTATION2 AVAYA 2490...
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
