Question about Whirlpool Refrigerators
The defrost cycle is not working on whirlpool refrigerator model # et1phkcxpt01
ghappliances
  • 126 Answers
SOURCE: whirpool side by side refrigerator ,fridges is not cooling at all
HI.YOU MIGHT WANT TO CHECK IF THE FAN IS WORKING WELL OR IF THE UNIT IS NOT OVER FREEZING WHICH CAN E A CAUSE OF THE FRIDGE NOT COOLING PROPERLY.FEEL FREE TO REQUEST MORE ADVICE IF NEEDED
Posted on May 04, 2009
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
huuum
  • 750 Answers
SOURCE: semi automatic defrost button won't pop up
The switch is broken and needs to be replaced.
This happens a lot
Huum
Please remember to leave feed back .
This is the answer.
click solve please1
Posted on Dec 09, 2008
alex_salve
  • 78 Answers
SOURCE: Refrigerator/freezer runs but never cycles off...
thermostat relay needs to be replaced
Posted on May 25, 2009
aasc
  • 1606 Answers
SOURCE: My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Posted on Sep 06, 2009
Whirlpool Gold Side by Side refrigerator GSS26C4XX, how to force the defrost?
With the bottom kick panel removed, look for a defrost timer. It will look like a small motor and have a slotted fitting on the end of the shaft - usually you can turn it only one way. With the unit running, slowly rotate the timer shaft 'till the compressor stops. That's the beginning of the defrost cycle, which will end when the timer makes a full revolution. It's usually 12 or 24 hours between defrost cycles.
If the box is completely electronically controlled (electronic logic board), you may not find a mechanical defrost timer.
Aug 03, 2017 | Whirlpool Refrigerators
Fridge not cooling whirlpool model gd5rhaxn000
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Aug 28, 2011 | Whirlpool S20DRSS33 Side by Side...
Whirlpool Model # ETClCHMXK009... Freezer is freezing but refrigerator is not cooling well...
Hi
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Daniel
Jul 17, 2011 | Whirlpool Refrigerators
Model WBM412 - Freezer works but fridge does not cool at all.
Its due to freezing behind the freezer coil by which freezer fan gets logged to function. Defrost the refrigerator and then run. Keep freezer temp between -14*F and 8*F and fridge temp between 36*F and 46* F. And also check defrost cycling is properly working.
Thanks, helpful?
Feb 26, 2011 | Whirlpool WBC3525 (12.36 cu. ft.) Bottom...
Whirlpool model ed5fhgxkq03 side by side. Lights
check your temp controll to make sure it isnt broken or open circuit also your defrost timer could be stuck in defrost! next check your compressor for running and see if it is hot!! or just warm? if it is just warm and cycling /running then your low on freon due to a internal leak
Jan 14, 2010 | Whirlpool ED2FHEXN Side by Side...
Water leaking into refrigerator. Looks like it is coming from the two holes in top of refrig box to freezer. Whirlpool model ET1CHMXKB03.
There is a small heater to evaporate the water after a defrost cycle. This defrost heater is gone and needs to be replaced.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool gold GS6NBEXRL01
hi .thanks for the question . the defrost cycle is probably on. either that or a faulty thermostat. thanks the appliance doc rate me please
Sep 10, 2008 | Whirlpool GD2SHGX Refrigerator
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
