Question about Brother IntelliFAX 4100 Laser Fax
Fuser replacement I need some help replacing the fuser on a Brother 4100. Is there a simple or straight forward way to get at it?? I am having difficulty taking it apart..
    Scholar:
  • 95 Answers
This is one of the most difficult repairs on this machine. It requires complete breakdown to the frame and I do not recomend anyone that is not familiar with copier/fax service try it! You have to take off everything down to the frame and it will take several attempts even for an expert to do this right the first time trying it!
Posted on Sep 23, 2009
  • 24 Answers
I also have a unit that makes noise and I was told by "Verdie" to try replacing the fuser. I have no idea even where to start... full detailed instructions would be greatly appreciated. I am a computer Tech and fax repair is new to me.
Posted on May 19, 2008
Hp lj 4100 50.2 error
is this error on a lj4100 or on a cm1017?
if on a 4100- then the complaint is that the fuser has not reached the required temperature in the allocated time- replace fuser kit with CORRECT fuser ( lm4100MKIT) and not a 4000 fuser which is not the same even though they look like each other.
if its a cm1017 then the error is poor communication with the thermal resistor measuring the fuser temp. again replace fuser kit to resolve
Dec 17, 2013 | HP LaserJet CM1017 MFP All-In-One Color...
My brother MFC 8860DN printer has an error showing: Rplace fuser. Does it have a fuser and where can I get it?
Open it up from the back of the machine. Try reseating the fuser first. If that does not help, then you need to replace it. Probably the ceramic fuser element is going bad? It is either not heating up fast enough or heating up too fast. If you can print test sheets, and the text is too shiny, it would be a fuser that is too hot. If you can rub the text off the test sheet, it is not fusing fast enough and there is not enough heat.
Try ebay for a fuser. They are fairly simple to replace.
Oct 13, 2010 | Brother MFC-8860DN Printer
Recieve the fax and print the pages well. But, when I send the fax to other fax it prints two black lines on the right side.
The problem should be from the printer fuser assembly, the other party will need to replace there fuser assembly on there printer, once that is done, the problem should be fix.
Take care.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
Fuser unit
dont. the whole machine has to be taken apart. not worth the time and the fuser is 85.00 wholesale.
May 24, 2008 | Brother IntelliFAX 4100 Laser Fax
FUSER REPLACEMENT
A real big job. Completely remove all covers, doc feeder asm. Best to let a qualified tech do it for you. I charge $50.00 plus parts and will allow you to watch me do it. But i am in Florida.
Fuser & Scanner are not the problem
Either the laser unit is dirty or blocked. Or the drum cartridge.
May 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Paper jam problem in laser printer 4100
if this happens every time you need to replace the fuser. but there is a possibility it could be the main gear drive assembly, 9 times out of 10 it's the fuser. a gear on the fuser usually breaks a few teeth. the fuser is very easy to replace and is a part that will eventually need replacing on all printers.
Jan 07, 2008 | HP LaserJet 4100 Printer
Brother 4750 fuser replacement
The entire front, sides, and rear cover is all one piece. Take the screws out and lift straight up.
Dec 14, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4100 Laser Fax Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
