Question about HP Office Equipment & Supplies
HP Deskjet F2480 has an ink stain due to ink spill in the carriage contact. area will it still function? How can I clean it ? Is a replacement part available in the market?
    Problem Solver:
  • 6 Answers
It will still print, u can clean the stain with fluid
Posted on Sep 13, 2010
HP Deskjet 5940 won't recognise new black ink cartridge
Check to make sure that the contacts on the printhead carriage is clean.. Remove both cartridges. Unplug printer.Wait at least 3 minutes. Plug printer back in. Printer will turn on. Reinstall cartridges.
Dec 30, 2013 | HP Deskjet 5940 Photo InkJet Printer
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
HOW DO I CHANGE INK CARTRIDGES ON HP DESKJET F2480
Refer the below link on how to change the ink catridges on hp deskjet F2480:
http://tinyurl.com/hpdeskjetf2480
Nov 22, 2010 | HP Computers & Internet
My HP 3210 printer seams to be leaking at the printer head. Just below where the 6 ink lines (6 lines in one wide black strip) enter the carriage. Ink is pooling under the base location of the printer...
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
You could carefully clean this as follows:
put the printer on some newspaper to avoid further spills.
Turn on the printer, then open the lid to allow the carriage to move to the center.
Now unplug the printer, then gently move the carriage to the left and out of the way.
You should now have limited access to the spittoon area.
You can clean this area by carefully scooping out the ***** of ink with a plastic spoon. (Be careful not to drop ink sludge on your printer, desk, carpet or clothing.)
Once most of the ink has been removed then use a crumpled paper towel to soak up the ink in the bottom of the service station.
It may take several rounds of this to clean up the service station.
It is not necessary to completely clean the service station, just get the majority of the ink out.
Once this has been completed you could turn the printer up and clean the bottom area of the printer. Do not tip up the printer before the service station has been cleaned or you are likely to create a mess....
hp printer ink cartridge
Sep 10, 2010 | Office Equipment & Supplies
I have a HP Photosmart C4150 All-in-One printer. The color inkjet cartridge is leaking profusely. Much ink is now smeared in the cartridge area, both the color cartridge and black cartridge area. If I...
http://www.fixya.com/support/t5703511-ink_cartridges_leaking_in
Sep 07, 2010 | HP Photosmart C4150 All-In-One InkJet...
Our hp deskjet 932C printer is leaking ink. What
May 09, 2010 | HP DeskJet 932c InkJet Printer
Unexpected Paper Size error while printing a3 size paper on HP 9300 deskjet printer
Although you have selected the paper size A3 your printer HP Deskjet show unexpected paper size.....
1. clean the carriage area ...........
2. change the carriage sensor....... If not solved
3. you need to replace carriage unit.
Thanks
Oct 26, 2009 | HP Deskjet 9300 C8136A Printer
HP deskjet 920C replaced both ink cartridges and now it prints in
When we see high page volume in these printers, the cleaning ink resorvor needs to be cleaned. It may be even to teh point of stopping the head cleaning carriage from functioning.
It sounds like it is not priming and wiping the head of the cartridges correctly.
You can also try setting the head of the cartridge on a damp warm (water wet) paper towel. If there is ink coming out onto the paper towel you know it is the printer not the cartridge. If you are not seeing any color then I would change the cartridges again.
May 12, 2009 | HP DeskJet 920c InkJet Printer
HP Deskjet 1220C cartridge recognition problem
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
The color ink in my hp deskjet 920c won't work
try cleaning the contacts (bronze like) with dry cloth both the cartridge and the cartridge holder most of the times there exist some liquid forms on both areas. since you frequently remove the cartridges; their might be a broken part on the cartridge holder. the broken part, use, is to make sure the cartridge is in absolute contact with the cartridge holder's. the size the said broken part is 2 mm in all sides. so small that it has a big function.you dnt even recognize.
Nov 07, 2006 | HP DeskJet 920c InkJet Printer
199 people viewed this question
Seeker5211
Seeker5211
