Well this stain of the ink on the back of the paper may be because of this reason there is a waste tank that eventually gets full after all the printhead tests it does after each print job and on each startup.
So to solve it you might have to take it out and empty it and then dry it off
I myself have solved this problem with my HP printer in an unususall way cause i ealier tried to clean it with paper towel, which actually did not helped
I lifted the printer off the 2nd paper tray and saw a huge puddle of ink on top of the 2nd paper tray which supported my suspicion of a full waste ink tank.
I carefully took the printer in the bath keeping it level to avoid dripping ink. In the bath I tilted it on the side where it was leaving ink stains and a large quantity of ink poured out.
I then ran the shower so water streamed under the printer to clean the bottom of it until the water at the other side started to be clear.
I then put the printer on paper towels and back on the 2nd paper tray. I left all lids open for several hours for it to dry.
I then plugged it back in and no more endless stains on the prints!
So there is a waste tank that eventually gets full after all the printhead tests it does after each print job and on each startup. I would have thought the ink would evaporate out of the waste tank or that HP would have had something to prevent this issue, after all 200 000 prints in 3 years is quite a bit less than the recommended use for this printer
You said one expert proposed a solution to my prolem.
You said I will provide a solution for $10.
After I paid $10 you said you will find a solution and email it to me. You did not have one expert that proposed a solution you wanted the $10 to look for a solution. Very misleading, I am still waiting for the one expert that proposed the solution!!!
After I paid the $10 you said
