Question about Toto Drake ADA Compliant Toilet with Elongated Bowl
TOTO DRAKE flushes then the tank fills, stops, then slowley leaks and the water just runs on and on at a trickle pace down the overflow spout.
  • 1,041 Answers
The rubber stopper that is inside the back of the tank is allowing water to get by do to:
(1.) Be wore out- must be replaced with a new one.
(2.) The chain that is connected to the flush handle needs to be adjusted. However, if it has not been messed with recently, then it will be the (1.)
Jim
Posted on Sep 14, 2010
  • Jim Parker
    Jim Parker Sep 19, 2010
    Thanks for the Rating!
    If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to
    Category:"Tools- Building
After flushing the toilet the bowl only a small amount of water comes back into bowl. This is a new problem. Could there be a clog?
Is the flapper valve closing sooner then it should? Is the water line (the 1/4" vinyl tube at top of fill valve) going into the tank or into the overflow tube? Did anyone drop anything into the flush valve?
Jul 02, 2014 | Toto Drake ADA Compliant Toilet with...
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
The water level in the bowl is too low after flushing. Can I adjust it somehow to leave more water in the bowl?
Make sure the fill tube in the tank from the fill valve is in the overflow tibe inside tank. The tube allows bowl to fill with water to correct level.
Aug 30, 2011 | Toto Drake ADA Compliant Toilet with...
The bowl on one of our Toto Drake toilets, after a flush is complete, has very very little water in it. I recently replaced the fill valve (used a Korky fill valve). Since then I have had this problem
The small tube that comes from the Korky fill valve needs to go down the center of the tube in the tank. It should have come with a clip to clip it inside the fill tube. If the tube is running water into the tank it is just filling up the tank, not the bowl. The tank is filled with the Korky valve from the top of the tower, not the black hose. See the video below to see the black tube I'm referring to and where it should be attached.
http://www.youtube.com/watch?v=bfE8gBV0gHI&feature=player_profilepage#t=92s
Jan 10, 2011 | Toto Drake 2pc. E/F Toilet CST744S-01
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
New Toto toilet continues to trick water
check the water level in your tank if it is filling ,ajust the float in your tank so it stops before going over the overflow. if not your flapper is the culpret
Sep 14, 2009 | Toto Washlet S400 for Power Gravity...
Toto Drake with Gmax that oesn't completely shut off.
When you look in the bowl of the toilet, do you see the water trickling? If so then the flapper needs to be replaced.
Also, does the water run intermitentedly? As in every 2 to 5 minutes does the water kick back on to refil the tank? If yes then the answer is yet again the flapper.
Now if the water is constantly running then you can try bending the float arm (the ron that is connected to the big floating ball) down and see if that helps. If not then the next step is to replace the fill valve assembly.
Both of these together will run you about $20-$30.
Apr 29, 2009 | Toto Drake ADA Compliant Toilet with...
Toto Drake ADA Compliant Toilet with Elongated Bowl Logo
541 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
