Question about Gateway Computers & Internet
WHEN MY COMPUTOR STARTS UP IT GOES TO THE SAFE SCREEN OPTION. WHEN I START NORMAL IT WILL SHOW XP WINDOWS STARTING AND THEN SUT DOWN AND RESTART AGAIN IT JUST KEEPS LOOPING. i HAVE ALSO TRYED STARTING IN THE SAFE MODE WITH NO CHANGE. I THINK MY HARD DRIVE IS JUNK IF THIS IS THE CASE HOW DO I RETRIVE SOME OF MY FILES?
  • 67 Answers
Try to login in safe mode.
open cmd.
type chkdsk and let the program check your hardidisk for failure if you think that it is the harddisk that is the problem.
option 2.
start your com.
press F8 before the boot screen appears.
choose : start up as last time the system worked.
hope you can use my help.
CS
Posted on May 15, 2008
Even after formating and installing windows, after cold restart when i start my system its showing me the screen with several options like safe mode, safe mode with networking, noramal mode, last best...
Chose normal mode, and start normally windows. Next time, make sure that you shut down, or restart computer in a proper way.
I hope I helped you, please rate my solution
Jul 30, 2011 | Microsoft Windows XP Professional With...
Tip
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
Why wont my computor shut down ? If I shut it down it suts down and after about 5 seconds it restarts
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
Feb 23, 2011 | Fujitsu Siemens SCALEO 700x...
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Eee pc won't start
sounds like a registry error try to start in safe mode if it does the same thing then when it starts to boot and says xp and the bar starts to move hold down the on off button till it goes off and let it set for a bit (let the hard drive stop turning) and reboot should send it into chkdisk whick will correct the registry error
Apr 17, 2009 | ASUS Eee PC 1000H Laptop
Look for windows recovery CD for AcerAspire 5610
It is good when you can start Safe mode it can help.
What realy happen when you start in 'Normal' mode ?
Do the following:
Start the computer in Safe mode.
Open My computer, than Right-click on Disk C and click on properties.
Click on Tools Tab and then click on 'Check Now', and then Start (leave two options above unchecked)
When it finishes, it should show that Disc check is complete, close it.
Right-click on My Computer, click on properties, and then Advanced Tab.
Click Settings in Startap and Recovery field.
Uncheck Automatically restart and then OK.
Now restart and see if it will bring Windows in 'Normal' mode.
Are there Errors, Blue Screen . . . . ?
If so, try one more thing.
Go to Windows start options (the one you go to select Safe mode) and go to
Last good known configuration
and pres Enter and once again, Enter.
Did you get to 'Normal' Windows ?
Mar 27, 2009 | Acer Aspire 5610-4648 Notebook
Help :( i can't start up my laptop it wont let me :(
what i can help this...
you select safe mode and remove video driver and reboot your laptop...if it inside the windows normally,try to remove some unused toolbar in add and remove programs..and check also for virus scan..and reboot computer..
Dec 16, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
Computers & Internet Logo
77 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
