Question about ASUS A7N8X-VM Motherboard
Usb ports not working
Hey,
just built my first computer and cannot find any help out there for this problem. My onboard usb ports do not work. neither does the on-board audio or the midi. i just installed the "all in one driver pack" from the asus website and usb, audio and such are showing up in the device manager now but they still don't work. i've check the bios and cant find anything useful there. i plugged in a pci card with 2 usb ports and that seems to work, but they are only usb 1.0. dont know where to go from here, any help would be appreciated.
  • 1 more comment
  • stilla May 15, 2008
    hi there and thank you for respoding to my post. as far as yellow ! there is only 1 and i belive it is from my mp3 player. there are several items in the DM that show generic drivers but that should be ok i would think. the pc uses windows xp pro service pack 2. i wouldnt use vista if i was paid to do so. i am only remoted into my pc at this point and cannot reboot until i get home. i have the following .net framework installed: 1.1, 2.0 service pack 1, CA, CRT, 1, winforms, 2, asp.net, preXP, Dr. Watson and CLR if that helps. i've rebooted after installing them. i have downloaded the driver/application from the asus link that you provided. in my device mngr, i do not see the "AC'97" driver to uninstal. i think that a generic windows driver may be already loaded into it. there are the following entries under "sound, video and game controllers": audio codecs, creative audioPCI (es1371,es1373)(WDM) - my soundblaster pci card, legacy audio drivers, legacy video capture devices, media control devices, Nvidia nforce Audio Codec interface, video codecs. i was successful in getting the pci soundblaster card to work and i get sound. sound really is good enough for me to keep the card in. the only problem now is that i have no on board usb ports. as i am not able to reboot, i cant get into my bios yet and will do so when i get home. after i get the plug and play os to no in the bios, i'll let you know how it went
  • stilla May 16, 2008
    hey, tried to make the change in the bios for plug and play os but it was already set to off. i do have 1 ! in my device mngr on "gmae port for creative" it still there even after i remove my mp3 player. i've tried to install the drivers that you suggested to that device but it will not accept them. anything else we can try at this point or do you think the usb ports are toast?
  • piusho Aug 07, 2008
    I have sound input ok out put not working
Dear sir,
I have a problem of voice of my PC
I have a Creative Audio PCI (ES1371,ES1373)(WDM) Audio devices
please send a link to download these drivers free for my PC
A lot of thanks to u
thanks
Posted on Sep 28, 2008
    President:
  • 2,351 Answers
Hi stilla, when you were in the device manager did you notice any yellow ! points? This is important for me to know, & will come in handy for re-installing you're audio driver software.
Since you setup this board I'm guessing you installed Windows XP (Home or Pro). (If you installed any version of Vista let me know because Vista is famous for loosing USB ports & CD-ROM drives). Vista will need other suggestive steps to repair.
It is suggested that you run windows update service. This is needed not only for security patches but also for USB ports and other devices connected to you're system. I'm hoping after you updating windows you're USB's will function. When installing update & you will come across .Net framework versions, please install only one at a time. Please do not sip any because there are updates for the update. When you finish updating you're system through windows update service, do not install service pack 3. Wait until these other problem has been addressed.
After the last Win update restart the system (Even if windows does not ask you to). Go back into & run windows update service again. (Choose Custom update this time).
After windows finishes checking you're system, look to the left side of the page. You are looking for hardware updates. If there are some, download & install. Next, restart you're PC and enter the bios. (Press the delete key every 2 seconds until the bios main menu opens). Set Plug & play OS to No. This will be within the Advanced menu.
This allows the bios to set Irq’s & DMA's instead of windows for the basic input & outputs of the motherboard. Pages 2-11 in you’re manual. (This has nothing to do with speeding up or slowing down the computer).
Click on this link. http://support.asus.com/download/download.aspx?modelname=A7N8X-VM&SLanguage=en-us
This will load Asus drive site for you're A7N8X-VM board. Click the + sign next to Audio. Create a folder on you're desktop & name it Realtek. Download the driver for you're OS & save the driver in the folder you created. The file alc650_wdma341.zip is compressed. You will need to uncompress the file & keep the uncompressed files within the same folder. If you do not have WinZip you can download a free 45 day trial version into you're PC. Free download:
http://www.download.com/WinZip/3000-2250_4-10003164.html
Once WinZip is installed right click once on the file alc650_wdma341.zip. A pop-up window will open, slide down to WinZip & left click, Extract to here. Open add/remove programs. Uninstall the sound driver AC'97. Restart you're PC. When windows finishes loading, open device manager. If there is a yellow ! point within Sound, audio and game controller, right click on it once. Than left click update driver. Windows hardware wizard will load. In the first window click No, not at this time. Click next. Click the circle, Install from a list or specific location & click next. Click in the box Search removable media, (This will remove the green check mark).
Than click the Browse button. Go to & open the folder you created (Realtek).
Click once on the folder WDM, than click OK. The downloaded driver software should install.
Windows sometimes just doesn't install some devices as it should & installing through device manager seems to work much better. Close all opened windows & restart you're PC. If you're sound still does not function than the onboard, integrated sound chip is defective or you're speakers are bad. You're board is beyond Asus 3 year warranty period. You will have to buy a PCI sound card to regain sound for you're system. I can suggest a replacement sound card from these links.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=290241
or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1567045&CatId=2771
Please let me know if the above suggestions have made a difference? Post any errors, problem or failures. If anything does not go well, explain what did not work so I can possibly help you farther. It's my goal to get you're system to function.
Good Luck!
Mike
Posted on May 15, 2008
  • Mike Peluso
    Mike Peluso May 16, 2008
    Hi stilla,
    My suggestion. (This is what I would do if I were repairing this board). A complete format & re-install Win XP Pro. I would use the CD-4-in drivers or down load the drivers from Asus. I would install the LAN driver first so I would be able to connect to the internet. The goal is not to have any generic drivers installed. Though this will take some time to perform it will also tell you weather you're board is slowly dying (I do not think this is the case or drivers did not install properly from the last setup of windows). It is very odd for onboard USB's not to function or not be seen by either bios or operating system. If you decide to do this, disconnect any add in cards. Re-enable (through the bios anything that may be turned off other than the PNP OS setting). Use the manual to help you while checking every setting on each page. You want to use the integrated devices on the board. Some of these devices must be enabled within the bios.
    If you have two hard drives installed in you're computer, use the second drive to back up you're personal data. Things like:
    User Name\Favorites, User Name\My Documents, User Name\Application Data\Microsoft\Address Book &
    User Name\Local Settings\Application Data\Identities. These hold most of you're personal data which can be copied back to you're system after windows has been re-installed.
    Bottom line you do not want to see any generic drivers within the device manager. Once removed with real Asus drivers, you're system should function as it is supposed to.
    Mike
Nosound
I am going to just have a few guesses at your problem as "nosound" doesnt really clarify it enough =]
If your onboard sound isnt working, You could try looking for an audio driver for this particular motherboard. Google "Intel D865GRH Onboard Sound Driver"
If you are using audio ports in a computer Case, make sure they are connected correctly to the motherboard, or use the audio ports on the back of the board.
Onboard sound does break on some of these older boards, Try using an external soundcard. (PCI or AGP) or a USB one. I picked a 7.1ch USB soundcard up off ebay for $8 and it works fine on all my old motherboards.
Hope this helps you, Best of luck.
Jul 11, 2011 | Intel D865GRH (KD865GRHLKPAK10)...
Hello i have hp rp5000 pc which have AGP port onboard but when i put graphic card in it it doesnt recognized it. I tried with another hp rp5000 bios but it doesnt work anyway-is there anysolution?
Erm, although the slot is labelled AGP1 (HEY HP Accelerated GRAPHICS Port 1 ???), it is not for a graphics card.
It is intended for an enhanced USB card that adds additional USB ports as well as 12volt and 24volt outputs.
The RP5000 was designed to be a POS (point of sale) unit and the additional ports were for devices such as barcode readers, handscanners and card readers to be plugged into.
Dec 25, 2009 | HP rp5000 PC Desktop
USB ports appear to not be working. Any clues?
Go to setup turn on the USB 1.1
The USB port is turned off for security reasons;
You may consider adding a 4 port USB 2.0 adaptor card my server has Both I use the onboard USB 1.1 for external hard drive and mouse
Nov 19, 2009 | Dell PowerEdge 4600 Server
My usb ports dont work in my toshiba satellite A135-S2386
Unplug the PCMCIA card first.
Then disable the onboard USB hub and ports. Shutdown, plug in the PCMCIA card and reboot into Windows.
Let Windows detect the card and if necessary put in the driver CD for the card. Had similar issues with my desktop PCI USB card.
After disabling the Onboard though it works perfectly fine now.
Hope this might help you a lot.
Please rate me if i a m helpful.
Thank you.
Beboy
Aug 18, 2009 | Toshiba Satellite A135-S2386 Notebook
USB ports won't work after hard drive format
hi
well u can try installing an USB PCI card .You must also check the usb status through device manager.For more technical help you can visit at------http://robs-tech.blogspot.com/2009/06/get-technical-support-related-to.html
Jun 21, 2009 | Sony VAIO VGN-FS742/W Notebook
Gigabyte GA-6VTXE Motherboard cant detect any USB pluged It used to detect JUST SanDisks memory, now... not even that. All windows updates installed. In manufacturer site theres just a 4in1 driver set that...
The problem is probably not software, but hardware. The BIOS probably has disabled the USB controller, or the USB controller has probably gone out, the way to tell is when you restart the computer, when the screen first comes up, press the DEL key to access the CMOS setup utility. Check around for something that says "Onboard USB Controller" or "Onboard USB Support" and if it is disabled, enable it. otherwise the Motherboard has lost the controller and you either replace the board, or get a USB controller PCI addon card. Hope that helps.
Jun 16, 2009 | Intel Motherboard
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Additional USB ports not recognised
seems that none of the ports are working
Jan 19, 2009 | ASUS P5PE-VM Motherboard
PCMICA/USB 2.0 not recognising usb devices
if it works on the onboard usb.
Theres a chance that either the pcmcia slot drivers are incorrect, or the actual slot is faulty.
Try it in another slot, if you have 1.
update any onboard device drivers. if applicable. try the card in a different laptop. to eliminate the card. alternatively, try a different card in the slot. wifi card et,c.
Mike @ compurepair.
Dec 16, 2008 | Compaq Armada M700 Notebook
Installing USB Hub
After installing the USB controller card into a PCI slot inside your computer, connect the 4 port hub to it with the supplied cable. (at the back of the computer)
Do not connect the DVD Recorder to the old usb ports. They will still work, but obviously not 2.0.
Connecting the power supply for the hub is optional, but usually a good idea.
If your computer still doesn't recognize the hub, make sure you have all of the latest windows updates and try running Add New Hardware in control panel. Also, just unplugging the hub and plugging it back in will sometimes work. Use a different port on the controller card if necessary.
As a last resort, you may need to disable the onboard usb controller through your system bios.
Good Luck
Sep 11, 2008 | CyberPower CPH420P 4-Port USB Hub
Open Questions:
I know I have a driver issue but how can I solve it???? I just installed a new motherboard asus a7n8x vm 400 I installed windows XP Sp1 but when I got done I could not get a internet connection so I upgraded to Windows 7 and still got the same problem but with a new issue. The first Issue I was having was the computer would not log online. Under the Network and sharing center I?m getting an unidentified network message keeping my system from obtaining a valid IP address. For some reason it?s stuck on public network and will not let me change it to home. I tried all of the basic trouble shooting first by turning on network discovery then I checked my network cable; reset my modem and router, and rebooted my computer. After cycling everything and still no internet connection I tried to manual assign a IP address. next I tried to go online using a different computer to find a updated driver and transfer them via flash drive with no luck just the windows is using the best driver message. I tried installing Driver Detective put when I try to launch the program it shuts down because it don?t have a internet connection. The second problem I?m having is a unknown device in device manager. When I check the device properties under general and location it say that its on my PCI standard ISA bridge. I do have a vt6421a IDE/SATA raid card in stalled in 1 of the 3 slots but when I uninstalled the device and shut down the computer and physically removed the card and rebooted the same thing popped back up. Updating the driver didn?t work I tried to go to the manufactures websites to get all driver updates with no luck. So what do you recommend?
Feb 28, 2017 | ASUS A7N8X-VM Motherboard
ASUS A7N8X-VM Motherboard Logo
366 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
