Question about Reliance Natural Gas Water Heater Control
Need to keep turning up tempature to get hot water
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
The thermostat probe inside the tank is scaling up with mineral buildup. You can drain the tank and then remove the control. Soak the thermostats probe in vinegar and a little baking soda. Do not let the mix get into the control box. Reinstall the control once the scale is removed. If this does not help, you will need to replace the control box.
Posted on Sep 14, 2010
Why do we need to have to continuously adjust the temperature of the water when we're taking a shower. We have a new Rheem gas .hot water tank
It *may* not be a problem with the water heater itself necessarily. When you say "keep adjusting the water temperature when you're taking a shower" I presume you're talking about turning the shower hot/cold knob(s) and not the temp thermostat on the water heater itself.
If so, when it starts to run colder, turn the knob all the way to full hot. Is the water then very hot? If so, the water heater is working fine & doing its job, and the problem is likely to be in the shower faucet mixing valve itself. Sometimes a faulty one will expand the inner seals/cartridge as hot water flows thru it, and starts to (wrongly) restrict the hot water flow, thus causing the constant need to "turn the dial up a notch".
Oct 29, 2014 | Rheem Water Heaters
How do i adjust the water tempature from the hot taps ?
you don't adjust hot water temp from the taps...
you can only adjust from the water heater.
what water heater do you have?
Aug 14, 2010 | Water Heaters
Our water heater runs out of hot water after a couple showers. Does it need to be replaced? Is there something on it that I can check? Does increasing the temperature setting help?
when was the last time that you have "opened the flush valve (faucet) at the bottom of the tank to clear out the sediment? if it has been more then 4 years then you will need to do this depending where you are located this should be done once a year just to keep the tank clean. attach your garden hose to the valve and run it over to the sink open the valve for a few moments to clear out the tanks bottom (HOT WATER ALERT!) after doing this and if you have seen dirt come out then your tank should be clear. check to see what the tempature is every 1/4 inch is 10-30* increase hope this helps
Jan 20, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I had our 1600ng Bosch water heater installed a month ago during warmer weather. It is not providing very hot showers. I use all hot no cold. how can io get more heat
on the front of the water heater down at the bottom there is a thermostat (usualy a blue knob) turning it clockwise will increase the tempature of your water
(good Luck)
Oct 12, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Stiebel Eltron tankless 24. Problem:No hot water.Tempature display dead.Single LED on right side comes on when cold water flows thru system.Have cleaned fine mesh input filter.No pressure problems. CCt...
Take off front cover, on the top of the two cylinders in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Oct 11, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hello, we have a demand water heater that we use at work since it is tankless it is different any the regular repair guys are not sure what is wrong with it . i was told it is a poloma gas model and the...
In most of the tankless water heaters the tempature of the warter is controled by the rate(amount) of vlow of the water passing through the unit. Turn down the flow of water going into the water heater and the water that is still passing through will be hotter. Carefully. A little at a time,so as not to be too hot.
Jan 19, 2009 | Stiebel Eltron CK20E Electric Tankless...
Inadequate hot water supply
Tankless Water heater tempature is regulated by the rate(amount) of water flowing through the device. To get warmer water for the hot side, slow down the elbo stop leading into the device. Since it is a shower,and you did not say one handle or two.You will have to slow the rate for the cold as well , if one, unless it is an ajustable valve. The drawbacks to the tankless heaters.
Jan 18, 2009 | Rheem Tankless Hot Water Heater...
I have two hot water tanks in an 11 unit building One side of the building has water coming out of the hot water spigots and the other side of the building has no water coming out of the hot spigots. There...
Duissamble the faucet after turning off the shutoff vavev and look for an obstruction. The only shutoff if the tempature gets too high is the pressure/tempature pop off valve which would redrirect the discharge down another path. Go to the waterheater and see if it is coming out from another open pipe from the heater.
Jan 17, 2009 | Water Heaters
Reliance Natural Gas Water Heater Control  Logo
55 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
