Question about Coby MP-610 MP3 Player
Headphone jack - Coby MP-610 MP3 Player
    Problem Solver:
  • 6 Answers
Ok, this is pretty much my first time, and im reparing this as i go along, so prepare for the worst. ok, what we are first going to beed to do is take out the back. stick your fingernail between the notches on the side. slide your thumb through and around it. it should pop off. next, you should see very VERY small sqrews. 4 of them. take them off and CAREFULLY pull the front apart. nect, with your index finger and thumb push the metals togeather that connect the jack. use your headphones so you can get a good fit. you might need to turn it on for good quality. when you think you got it, put everything back togeather carefully. it worked for me and you should got it now.
-Reoko
Posted on Sep 29, 2010
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
Headphone jack requires bending the headphone jack to a side to get stereo. this is the coby mp725 16 gig love the unit. got it as a gift. had to send my first unit in due to headphone jack not working....
This problem is common with a lot of MP3 players. It is caused by excessive movement of the headphone jack and causes the headphone jack has worked loose from the circuit board.
To fix this problem the MP3 player needs dismantling and the headphone jack needs resoldering onto the circuit board to get the headphone working properly.
Jun 30, 2011 | Coby MP725Digital Media Player
Do I need to buy a seperate headphone jack adapter in order to put my headphones in? The headphone jack seems too small. If so what should I buy?
What type of headphone connector do you have? The Yamaha keyboard headphone jack is a 3.5 mm stereo jack (like on a computer headphone jack). So if the headphones have a 1/4" plug, you need a 1/4" to 3.5 mm adapter.
I hope this helps.
Dec 26, 2010 | Yamaha YPT220 PAK 61 Key Keyboard wAC...
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Headphone Jack issue Sansa View 32GB
Buy a broken one with the headphone jack intact off Ebay and switch the jacks.
Sep 08, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Apr 22, 2009 | E-Machines T2898 (764296109563) PC Desktop
Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Dec 13, 2008 | Toshiba Satelite A10 Notebook
My headphones won't work!
look at the headphone jack, if it has 3 band, it is a stereo jack. the computer is mono.
you need a 2 band jack.
if you look at the jack on the computer, you will see blue(left) and green (right). you canna try to use the green jack.
go to any electroic shop and get a stereo to mono converter.
Dec 05, 2008 | Sky Hawk Computers (PSR5601W-SL) ATX...
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Small headphone jack on crap headphones from Brookstone.
i used a cellphone adopter when my headphones broke.
Nov 28, 2007 | Brookstone TinyTunes MP3 Player
Coby MP-610  MP3 Player Logo
56 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
