Question about Nokia N72 Cellular Phone
N72 screen blank.
I have not used my Nokia N72 Cellular Phone for about 3-4 months and it was switched off. Now when I am trying to put it on it shows blank white screen. I have tried by recharging it and even removing the battery but with no luck. Please help.
  • 1 more comment
  • Anonymous May 31, 2008
    Even I am having same problems
  • Anonymous Jun 17, 2008
    I can call and receive incoming calls but the screen doesn't show anything. I even tried updating the software but it didn't work out
  • dinesh kumar
    dinesh kumar May 11, 2010
    I have not used my Nokia N72 Cellular Phone i vemove battery. now when i am trying to put it on it is locked. Please help.
Just Update ur Phone Software.Remove ur memory card and update.It will do well
Posted on May 31, 2008
  • raajith May 31, 2008
    Note: Your datas in Phone Memory Will be completly erased
My nokia n72 phone's flash is not giving proper light when the flash is on.Rather it gives a faint light.pl.solve my problem
please format the phone , use this code to format the phone
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
then try to use the camera and check the flash,
if the problem check the flash hardware
Oct 25, 2010 | Nokia N72 Cellular Phone
I am unable to put the lock on my cell nokia n72. my cell code is 359400003259792 please send me master code.
first try to format the phone using the code below
your problem is again continuing go to a mechanic and ask him to flash the mobile ( re-install the software ) it costs around rs 100 to 150 - this helps to reset the code
please rate me if it helps u
Oct 22, 2010 | Nokia N72 Cellular Phone
Hai iam using n72 it falldown and it switch off i
Oh, very bad. Think you try remove the battery and insert again, turn on the phone. If it's still show blank screen, maybe your phone was crashed. Bring it to Nokia care, maybe they can help you!
Mar 13, 2010 | Nokia N72 Cellular Phone
Can a technician in the house tell me the steps to follow, i want to repair my blank nokia screen
Do you have a white, blue screen or no display at all?
If you are able to turn on your phone but it remains blank, you can format it.
How ever this will erase all your phone memory data as your phone is restored to factory settings.
Your memory card and SIM card data will not be affected how ever.
To format your phone, use the following steps.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Make sure you have at least 3/4 charge of battery power left.
2. Switch-off your phone.
3. Press and hold these 3 keys; Green dial key, * (star key) and no. 3 key and then press the power on/off to switch on the phone.
Remember, do not let go all of the keys, hold until you see a formatting word screen show!
4. After a few minutes when the full phone formatting completed, your phone will be back to original system and factory settings.
Jan 08, 2010 | Nokia N72 Cellular Phone
N72 screen goes blank
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is the solution! Please vote!
May 17, 2009 | Nokia N72 Cellular Phone
My n72 cell not switced on
It happens when the OS got corrupts.....u switch on it for4-5 times it will get started(but its not for permanent) then save all your important stuffs into ur pc then go to a nokia priority dealer and re-install the software....
Jan 29, 2009 | Nokia N72 Cellular Phone
Screen became blank- N72
this happens with me sometimes when my phone battery is empty and i connect it to the charge what i do is just remove the battery from the phone then put it again and it should work normally
Oct 24, 2008 | Nokia N72 Cellular Phone
N72 white display
My N72 (Nokia) phone’s display shows blank when switched-ON. Blank in the sense means that the display lights are ON, but no images in the display. Sometime the dispay comes and goes. In addition, the phone is not ringing or can’t make calls. Can anybody help me?
Oct 23, 2008 | Nokia N72 Cellular Phone
How to format n72 cellphone not memory card only cellphone
this is a simple one that so many people ask ,there is no risk to do just do as i say
if u want to format memory card first format it,then
to format phone,,,,,,,
first remove memory card,then switch off the phone for 2 min and then switch on by pressing n holding the keys ASTERIK(*),3,CALLKEY(GREEN KEY).THATS ALL PHONE COMES TO ORIGIN.
NOTE:THREE KEYS SHOULD BE PRESS N HOLD WHILE SITCHING ON.
AFTER GETTING SOLVED U JUST VOTE ME / MSG ME.OK GD BYE...
Feb 18, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
205 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
