Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
I have the Vanguard 16hp 303776. when running sounds like slight air leak, when mower is engaged almost dies right out (no power)
2 Suggested Answers
Rayvin1943
  • 97 Answers
SOURCE: Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Posted on Jul 19, 2009
16hp vanguard pressure washer sputtering while running what need to be done for smoother running
Sounds like the engine choke is "ON" or the air cleaner is dirty. Engine may be running "Rich".
Nov 16, 2014 | Garden
16hp v-twin ohv vanguard
it seem like your gas line is sucking some were
Jun 25, 2013 | Craftsman Garden
16hp horz vanguard, only starts with pull start,when running the lights won't work......
have a load test done on the battery as it appears to fail when the current draw is high as in starting taking the current needed to run the ignition syatem
Mar 16, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton 16HP carb small hose purpose? Have a Snapper riding mower with 16HP Briggs & Stratton16 HP V-TWIN OHV Vanguard, Model 303777 Type 1145-A1 4750 Code 97021011. It started...
Should go to the valve spring access cover. Is the PCV line and keeps engine from building up pressure internally.
To clean the carb you will have to remove it from the engine and give it a through cleaning with small diameter wires run through the ports and blowing out the gunk with low pressure air or WD40's little red tube. From your description, you need to do this as the ports are clogged and not letting proper amounts of fuel through to the engine.
good luck.
Sep 16, 2012 | Tools & Hardware - Others
Simplicity riding mower with 16HP Kohler engine stalls after about 15 minutes. Acts like it isn't getting any fuel, but it will run again later.
I have seen this problem a few times and this may not be the solution however, check the fuel filter. It may have melted and partially closed off the fuel supply. The routing of the fuel hose will cause the inlet end to bend slightly if it gets too hot under the hood.
Aug 24, 2012 | Simplicity 44in Broadmoor Lawn Tractor...
B &S 16hp engine on a riding lawn mower. Engine model #303777 Type 0015-02. 420 hours on tach. Under load engine hestates and dies. Will restart immediately, run a few minutes and die again. Without...
check the fuel cap too,, it needs to be venting for better fuel flow, also,, when was the last time it got plugs,, it may be flooding out due to weak spark
Jul 07, 2011 | Garden
Hi , i have a craftsman 16hp model 944 602261 the engine run fine and the tractor work fine on each speed but when i engage the blade the engine dies the blade are free any idees ???
When you engage the blades you are putting an extra load on the engine. This mean it needs more fuel and more air to keep running.
I suggest cleaning or replacing the air filter, it may be clogged just enough to let the engine run with little load, but when you put a load it cant get enough air. This happened with my string trimmer this summer.
If that doesn't fix it then I recommend pulling off the carburetor (between the air filter box and the engine), taking it apart and cleaning it with carburetor cleaner. If its getting enough air at full load then it isn't getting enough fuel, there could be a partial blockage of the jets inside the carburetor.
Jun 10, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
May 04, 2017 | Briggs & Stratton Briggs Stratton Vanguard...
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
114 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
Daryl Gleaton
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
