Question about Nyko Charge Station for Nintendo Wii
My nyko wii remote charger lights up green but the wii remote is not fully charged.
3 Suggested Answers
  • 69 Answers
SOURCE: How do I connect the Nyko wii remote to the wii?
You must first sync the remote and consul.To do this you take off the back of the remote then hit the red button.Their is a red button on the consul that you need to push at the same time then push the a button on the remote.If you are trying to hook up the old style Nintendo controller then you plug the controller in to the end of the wii remoute the same way you hook up the nunchuk.
Posted on Mar 08, 2010
SOURCE: My wii remotes aren't charging!
put new batteries in them
Posted on Apr 03, 2009
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Apr 22, 2013 | Nintendo Wii Remote Control 4 Charging...
Only one light works
no it does not. the LED light may not be working correctly
Dec 17, 2012 | Nyko Charge Station for Nintendo Wii
Hi. We have a NYKO Charge Station for the XBox 360.. What do the indicator lights.. Green? Red? Thanks.
Hello
The red light means its charging, then when its done charging it turns green briefly then the lights and charger turn off and the controller is ready.
Please rate.
Aug 17, 2011 | Nyko Charge Station 360 For Xbox 360
The lights on the charge station are both blinking quick flashes of green without a remote on it - when I put the remote on it, there is no change in the blinking lights. I have no idea what's wrong - can...
Try contacting Nyko company to see if they have any solution. www.nyko.com I have the same charge station and discontinued using it because it would not charge my controllers after only a few months of use.
Mar 02, 2011 | Nyko Charge Station for Nintendo Wii
What to i need to do when the wii charger is green
If your controller is still sat in the charger then that is fine when the green light is on. The chargers have what is called smart charge technology. This means that when the controllers reach full battery capacity the charger stops sending charge to the controller until it drops below a certain charge level again. Leaving the remotes in the charger when the green light is on will not damage them in any way at all.
Hope this helps
Dec 19, 2010 | Nyko Charge Station for Nintendo Wii
My wii remote charger keeps blinking red while charging the remotes
@VentureForth
You're an idiot. The flashing red light is ON HIS CHARGER FOR HIS WIIMOTES. So why the hell would it be a sync issue with the wiimotes and the wii console? READ the WHOLE question before making yourself look stupid.
Aug 16, 2010 | Nyko Charge Station for Nintendo Wii
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
Light is blue when charging.. then green. What do the colors mean? I just got this used from someone and it doesn't seem to be taking a charge.
It is supposed to be blue initially. That indicates it is charging.
When it switches to green - the controllers are fully charged.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 04, 2010 | Nyko Charge Station for Nintendo Wii
Battery Not Charging
I had this same problem and searched on the web for answers.... I could not find an answer; just complaints. I tried something that solved the problem! I noticed a greenish buildup on one of the three metal contacts on the battery. I wiped the green stuff off then the battery charged as normal.
The problem I was having (to ensure we have the same problem) was that the wii indicated the battery was out of power. I would put the remote in the charger and the indicator light would turn blue to show it was charging. A few seconds later the light would turn green to indicate it was done charging and was full. However, the battery was still empty. This would occur even if I left the remote in the charge overnight.
With the fix I listed above, the batteries now work as normal!
Aug 20, 2008 | Nyko Charge Station for Nintendo Wii
Wii charger not charging
problem is either one battery is discharged and the other is full or corrosion on battery terminal tops or batteries are defective. the red lights flash when the unit sences that the batteries have a problem with the induction charge. simple test is to using a meter measure the batteries or discharge the unit with a wire and a 2.2 volt bulb (flashlight bulb) once discharged, unplug the charger unit for over 10 secs to reset it. then plug it in and try the batteries in the packs again. if still inop then they are done for.
Aug 15, 2008 | Nintendo Wii Console
Nyko Charge Station  for Nintendo Wii Logo
729 people viewed this question
Top Nyko Video Game Consoles & Games Experts
James Wishart
Are you a Nyko Video Game Console and Game Expert? Answer questions, earn points and help others
