Question about Acer Computers & Internet
I have a acer 4222WLMi and the power plug broke. what is the best way to fix it? i guess the cheapest way. Basically, the power plug broke off. do i need a new mother board? please help thank you. hector
  • hecmoon Sep 13, 2010
    i don't think it can be solder the plug is completely broken... anyway it can be by-pass?
    have an schematic?
    Where is the post that shows how to solder it back? can u show me?
    Master:
  • 515 Answers
You might like to check the following post to know how to sold it back if the jack on the motherboard is broken. If the cable is broken, you can get a general one with the same voltage range and maximum current range. Be sure to have one with very similar voltage as the original one.
Posted on Sep 13, 2010
  • Donald Huang Sep 14, 2010
    If it is broken to pieces, I am not sure whether you can get some parts on ebay. It might be a good idea to use the power jack in case it changed the voltages to the parts it connects to. If you need to by-pass it, you can check the power cord, mainboard print or some specification manual and see what are the voltage requirements for the parts it connects to. Then you can connect power sources with those voltages and maximum current to those parts by solding the parts to another power source like a voltage converter. Would you like to send a picture to me showing what the power jack look like now? donaldhuang@live.ca
2003 buick lesabre heated seats are not working
Best guess is a bad fuse. It's also the cheapest easiest fix which is what my dad taught me. Basically, when hear hoof beats, think horses not zebras. A Chilton/Haynes repair manual will provide a fuse panel map etc.
May 02, 2017 | Buick Cars & Trucks
Can a motherboard from another acer work to acer 3275?
I doubt it will fit inside your laptop. Laptop cases usually are designed for a particular model laptop.
Mar 10, 2012 | Acer TravelMate 4222WLMi Notebook
I have an Acer TRAVELMATE 4222 and tried to restore the problem by installing the Microsoft 2003 disc but it tells me that windows 32 is missing. Can I resolve this problem? How does one reformate this...
Hi
i believe it could be in your programs
start
program
acer empowering technologies
acer erecovery management
recovery
then follow onscreen instructions
but please if you have the option save any important items like files or photo,s to
a spare drive or disk before you do this as you will loose all you put on and it will format your drive
and hopefully restore back to factory settings
if you cannot start the laptop correctly
then try to press the power key along with the alt+f10 key i believe this will start the recovery
Apr 04, 2011 | Acer TravelMate 4222WLMi Notebook
I just installed windows 7 32 bit in my acer travelmate 4222, everything is fine except for sound. there is no sound in speakers but sound from headphone jack is coming. i checked acer's site but there...
Hello
If the sound is coming from headphone jack then its mean that the drivers and windows installed correctly, you may check the speakers and speakers connection of your laptop. the speaker jack may be loosen or speakers may gone faulty.
Hope this helps, if so do rate the solution
Jan 05, 2011 | Acer TravelMate 4222WLMi Notebook
Please how can i get the complete drivers for acer travelmate 4222wlmi
go to < http://driversguide.com > register for free and search here, many people share their drivers and also the PC's manufacturer's support website is listed.
Nov 30, 2009 | Acer TravelMate 4222WLMi Notebook
Acer travelmate 2480 the pin broke and is in the power plug
Don't try solder it. you will burn up *********** board. put some super glue on a tooth pick and pull out the pin and get a new power plug
Aug 01, 2009 | Acer TravelMate 2480-2968 Notebook
Is there any way to fix my screen kids broke it backwards and now the monitor isn't working
My guess is that they pulled the wires loose, if you remove the keyboard and look underneath there will be wires from the display going to a plug. You'll have to check Acers web site on how to remove the keyboard. they should have a repair manual you can down load(Problbly a PDF Document)
Mar 23, 2009 | Acer Aspire 4520-5582 Notebook
Gear Shift Problems
a wrecking yard would be my best guess for a replacement steering column, cheapest also.
May 22, 2017 | 1999 Dodge Ram
Lines on the Screen
2 possibilities video card is damaged and bleeding ac power from the motherboard or the motherboard is damaged from a power spike and is bleeding ac power into the video card(this would be my best guess based on yur description). that is the best i can do on this info you have given I recommend you take it in to a service center for a definitive answer.
Jul 22, 2008 | Acer X221WSD Monitor
Battery door cover
As a first call I would try visiting the smaller specialist camera shops that do repairs.
The manufacturers are starting to hide behind blanket 1 year warranties that only cover manufacturing defects. Basically if it works when you first use it - they won't help on anything else as it comes under "improper use" or "physical damage"
They are producing them cheaper than they can repair them, so, if you do return a genuine claim within a year - they send you a new one, and bin the old one.
They also charge high prices for repairs.
My personal advice is to watch Ebay for an identical model sold for spares. Just do a search,save it and they will email any matches to you.
Then just swap defective parts.
This is the cheapest option.
Jul 04, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
