Question about American Standard WCZ036F Air Conditioner
I replased the blower moter and i dont now how the wirering goes
  • 144 Answers
Purple wire common to capacitor brown fan terminal to capacitor capacitor is a canister that wires plug into it has three legs common fan and herm your last wire may go to contactor or defrost board or fan relay if you look on you drawing it will tell you where these go if its a indoor blower it is breviated idm if outdoor fan it will be odm all wires are color coded and fairly easy to trace you can also cross-out the wires that are hooked up in the unit with the drawing leaving those three but above all make sure the power is off when doing this a capcitor produces more power it turns 120v into 370 volt
Posted on Sep 13, 2010
The furnace goes on but turns off.Its not even 2 yrs since its been put it.I changed the batteries in the thermostat.what should i do??
This sounds to me like your hot surface igniter has burned out. shortly after the induction moter starts you should see a bright glow in the heat exchanger; if you dont you need to change the igniter. In most cases the blower moter will come on and blow cold air, this is a default setting.
Apr 19, 2011 | Goodman GMS90703BXA Heater
Put new fan moter on unit. but now it runs backwords. dont know what wirers to change . thanks.
If you are talking about the outdoor condenser fan motor, the wires that are on the **** end of the motor that are plugged together, you just take and reverse the 2. Very easy to do, there is only one other way they will go. This will reverse the direction.
Shastalaker7
A/C, & Heating Contractor
Mar 29, 2011 | Heating & Cooling
Where would i find the relay for the blower moter. the fan dont shut off even with the key off 02 bonneville
The relay will be a module,it is mounted near the blower motor and has multi-wires going to it.
Jan 13, 2011 | 2002 Pontiac Bonneville
Replaced the climate control and blower wont work
f that just put power to the blower moter and see it it runs if you pull the relay jump a wire across the terminals with it out and add a ground wire to the case of the blower to another spot on the chasis if it still does not run your blower switch may be bad dont worry just run a toggle switch to a good blower moter
Feb 28, 2010 | 1998 Pontiac Grand Prix
Blower moter works on bench test fuses all goodpower to blower still dont work
has to be a connectin from switch to motor
broken wire or bad connection
Feb 19, 2010 | 2000 Jeep Grand Cherokee
Air and heat dont blow hard any more
Sounds like you have a bad blower moter resistor.
The resistor assembly is located on the heater box module
under the dash near the blower moter. Hope this helps.
Feb 19, 2010 | 2000 Chevrolet Silverado
I HAVE A 1994 OLDS SILHOUETTE AND THE FRONT BLOWER MOTER FOR THE HEAT HAS BEEN ACTING UP SOMETIMES IT WORKS SOMETIMES IT DOESNT AND NOW IT WONT WORK AT ALL BUT THE BACK ONE WORKS JUST FINE I HAVE CHECKED...
bad connection right at the blower motor. put the blower motor on and wiggle the two wirer connector. this is the most likely cause and the fix is to bend the prongs to get a tight fit again in the connector.
Dec 26, 2009 | 1994 Oldsmobile Silhouette
Blower motor 94 dodge intrepid inop
1.disconect battery
2. remove lower right undre panel silencer duct
3. remove the blower moter connector from the resistor block
4. squeeze the blower moter wiring gromment and push the gromment throw the blower moter housing cover
5. remove blower moter housing
6.romove the screws holding the blower moter down
to put back on do the steps back werds
Jan 03, 2009 | 1994 Dodge Intrepid
American Standard WCZ036F Air Conditioner Logo
82 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
ROCKIT957
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
