Question about Mantis Tiller
My mantis tiller starts ok and runs for about one minute then dies. It will start again but dies again. Any suggestions
  • whitehouse60 Sep 19, 2010
    Sounds like I need to order a Carborator kit. I checked the things you recommended.
  • 1,041 Answers
Thanks for accepting my bid!
The first thing I would check is the gas cap. The gas cap breathing holes can become blocked with dirt, not allowing the carburetor to breath, choking out the motor. The best way to test this is to loosen the gas cap right before the motor dies. If it starts to run again, then you know the gas cap is clogged. If it dies anyway, then you know it's not the gas cap.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carburetor cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Sep 19, 2010
  • Jim Parker
    Jim Parker Sep 19, 2010
    That is quite possible. But if you use the Den Tek brush on the small portals in your carb., you may be amazed at the results! The small carburetors can be very temperamental. And who knows, you may save yourself a few bucks. And, if the portals are blocked, a new carb. kit won't help until this is resolved.
    Good Luck! let me know if you have other questions.
    Jim
  • Jim Parker
    Jim Parker Sep 21, 2010
    Thanks for the rating!
    If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Mantis tiller 7222e
Hi anon, if it's starting your 2/3rds of the way there. You have fuel and spark. Try and clean the air filter first and if that fails to keep it running then check that the choke isn't staying out. If all thats ok then it may be the carb gaskets.
Jul 09, 2014 | Mantis 2-Cycle Tiller
Engine dies when put under load
Its running lean. Needs adjustment or carb rebuild
Aug 30, 2012 | Mantis 2-Cycle Tiller
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Mantis tiller keeps shutting off
One screw is fuel and one is air, try turning the screws in all the way then open three turns and start from there.
Apr 07, 2010 | Mantis 2-Cycle Tiller
Engine will crank with starting fluid, but dies.
Have you checked the spark plug and see if its clean and also check the fuel line and carburetor for clogs. And you can also check the air filter.
Hope you find this helpful.
Jul 09, 2009 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Mantis to stroke start not very easy once it starts use for five minutes then it stops and doesn't start again I bought this from the ebay in February 2009 and I paid under £175 when I bought it the person...
either the choke is still on
or
the air filter is so dirty that it is acting like a choke
either way, replace your spark plug and air filter
if your air filter is foam, you can clean it in gasoline, just be sure to air dry it before refitting it and tring to run the mantis
the carburator can be dirty and or having the screws out of adjustment.
thy the spark plug and airfilter first
Apr 01, 2009 | Mantis Electric Mini Tiller/Cultivator
Mantis tiller 2 cycle seemed as if it was running out of gas
Check fuel filter and lines, if thay are good I would get a carb kit and set the adjustment screws at 1 turn out from lightley seated to start. Don't lean high speed screw too much.
You might check muffler & cylinder port for carbon first.
Mar 20, 2009 | Mantis 2-Cycle Tiller
Mantis Tiller Logo
1,430 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
