Question about Samsung RS2630SH Side by Side Refrigerator
I have a Samsung RS21DPSM, three years old and sudenly started flicking on and off, no sound of the motor running.
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
This may help / explain ">
Posted on Sep 15, 2010
I have a Samsung SMH9187 about three-four years old I think. It does not heat -- everything else works. When turned on it at first makes a grinding type noise and sparks can be seen inside where the motor...
The magnetron won't make a grinding noise so that makes it sound like the fan motor bearings are bad. However if it doesn't heat, that sounds like the magnetron.
Jun 12, 2014 | Microwave Ovens
My Samsung RS21DPSM is not freezing, the fridge is working and the fan in the fridge is not loud. The freezer is not freezing.
Check the condenser fan in the compressor department. The fan motor is know to fail. The refrigerator and freezer temps will be cool but not cold. I would start there.
Apr 02, 2014 | Freezers
Samsung refridgerator regularly beeps with power freeze switching on and off
Sounds like a faulty temperature sensor calling and not calling for the power freeze to come on. Change the sensor!
Jan 01, 2013 | Samsung Refrigerators
Window air conditioner loud when compressor kicks in
Possible that compressor motor internal mountings broke.
Apr 07, 2010 | Heating & Cooling
American Standard Freedom 90 Draft Motor woes
There is a gasket that usually goes around the outer edge of the draft motor, but I don't see that causing the gravel sound. By the way it sounds, your not missing anything, but on occasion, bumping the flue vent around causes the rust build up to fall into the motor which causes the same sound you described. If this is the case, you can either wait for it to go away or take it back of to clear it out. Hope this helps some. Good luck!
Mar 13, 2010 | Heating & Cooling
No water enters the inside of the dishwasher and the motor makes a sound as if under strain. It was working perfectly and then sudenly started leaking from underneath. Could not locate the leak yet. Old...
it is leaking from the seal above the motor in the centre bottom of your machine also check the door seal they tend to leak on older machines as well
Dec 14, 2009 | Dishwashers
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
hi
i had the same problem with mine,and fixed it very easily in about 10 minutes all you do is take all the shelves and draws out, then remove the light cover (one screw at the top)then the bulbs,there are three screws on this panel top middel and bottom,take these out,now gently pull the panel off,behind are two plugs unplug these and completly remove the panel.
next unscrew the water chiller at the bottom of the fridge and lay it in the botttom,take the deoderizer cartreges out and remove the two screws out from behind there,just two more screws at the bottom of the panel,there should be two plugs at the top of the panel,unplug these and remove the panel completley ,if like me you should find the fan all iced up, some warm water on a spunge should remove this and the fan should move freely if the ice is severe then remove the fan motor and run the panel under some hot water untill the ice is gone,assuming the motor is'nt burnt out this should cure it.if you want to test it plug the panel back in also the light panel ,and hold the light switch after about 30 seconds to a minute the fan should run,now just put it back together and thats it....
hope this helps
Apr 23, 2009 | Freezers
Noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Feb 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
May 11, 2008 | Heating & Cooling
Samsung rs21dpsm
It may be that the air vent is blocked by something as well but the filter is usually behind the air grills.
Thanks J
Dec 24, 2007 | Freezers
Samsung RS2630SH Side by Side Refrigerator Logo
188 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
