Question about Xerox Office Equipment & Supplies
Power failure when i switch on the the power it appears E004 error and the the power shutdown.
  • 86 Answers
Check with the power card & power point with the multimeter proper voltage is coming R not.
Posted on May 18, 2008
What does the error message E005 & 004 mean
Hi there
regarding E005 , E004 at JUKI lock stitch machine means :
E004:
synchronizer lower position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
E005:
synchronizer upper position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
if still not solve please change synchronizer with new one.
BEST REGARDS
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 04, 2014 | Juki DDL-8700
Canon np 7161 E004 error
Ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, kibokoyao waiting for your vote.
Apr 26, 2012 | Office Equipment & Supplies
I keep getting error message E004-0002 ( Switch off and on again) everythime I switch on my canon clc 1000
E004 is a temperature related error. You would need to call in a service technician as it will require replacement parts.
Sep 12, 2011 | Canon CLC 1000 Color Copier
I have imagerunner 1630 has code e000 how can i fix it
If the machine detects an error in the fixing assembly, the DC controller PCB operates
as follows:
[1] It causes the FSRDRV* signal to go '1' to cut power to the fixing heater.
[2] It causes the RLYDRV signal to go '0' to turn off RL1, and indicates 'E000' through
'E004' on the LCD in the control panel.
When 'E000' through 'E004' is indicated, the NVRAM on the DC controller
PCB remembers an error in the fixing assembly even when the
power switch is turned off and then on. After turning on the power, be
sure to execute the following in service mode to remove the error information:
#7 PRINTER > #4 PRINTER RESET > YES = (*).
sonsunny
Jul 06, 2011 | Canon imageRUNNER 1630 Copier
System error 004
E004 Fixing unit failure
E100 Scanner unit failure
E246 The Counter board is left out
E676 Communication error
E677/6F-61 ROM check error
E677/6F-63 RAM error
E733 A fault occurred in the communication between the SCNT board
and ECU board/TOP signal cannot be detected
New E805 Fan failure
TRY THIS:
Cause: (1) Shorted/broken wired main thermistor
(2) Shorted/broken wired sub thermistor
(3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J301-1
(FSRTH) and J301-2 (GND).
If the resistance is not within the range between 350 W and 520 W
(room temperature of 20°C), replace the fixing film unit.
(2) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J302-1
(FSRTH2) and J302-2 (GND).
If the resistance is not within the range between 360 W and 530 W
(3) With the fixing film unit removed, if there is no continuity
between the fixing unit connectors J303-1 (ACN) and J303-3
(ACH), replace the fixing film unit.
(4) Replace the EPU board.
(5) Replace the ECU board.
Jun 24, 2010 | Canon Office Equipment & Supplies
Panasonic AG-DS550 VCR shuts itself down about 2 seconds after switched on. No error code appears in that brief interval. Toggling the power switch immediately is ineffective, but after waiting a while,...
This is a typical symptom of a power supply failure. There are some self-checks performed at power-up that are not completing correctly. Were there any symptoms before the complete failure? Often, the units start to behave strangely before complete shutdown. The power supply failure is tied to defective capacitors in most cases. These supplies are what are called "switch-mode" supplies and must oscillate to work. Defective caps will either not provide the kikcker to start the oscillation or prevent the oscillation completely. While there are other causes, this is the most common. AG units are professional decks and should be serviced by authorized service centers.
Hope this helps,
Dan
Dec 07, 2009 | Panasonic Televison & Video
E004
A E004 deals with the fuser unit. Have you looked at the Thermister or the thermal fuse or the fixing lamps? I would say that most likely you have a blown or shorted thermister. One of the wires may have come off the pcb.. I you want to see the error code, I believe it is under *6* counters... *4* is for resetting the code
Jul 14, 2009 | Canon NP 6050 Copier
Canon Laser Class 730i Printer/Fax -- Error Code/Alarm E004. How do I clear it?
E004 Fixing Unit Failure.
I would recomend calling repair Tech to resolve this issue....unless you know how to access service mode and perform a Printer Reset operation. Could be complete Fuser Unit failure.
Jun 02, 2009 | Canon 730i Laser Printer
88 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
