Question about Datacard Group SP75 Color Card Printer
Hi, i have a problem datacard sp75 error op-01604, l1-heater error
  • 36 Answers
SOURCE: We have a Datacard SP75 printer, and it is running
there is a fan in the top of the printer, that may very well be the problem
Posted on Mar 18, 2010
SOURCE: Printer Head Cleaning
It's in the blue plastic cover. Power down the SP75. Open cover to see the printhead. You'll see a green stripe. The printhead is in front of the stripe. Use an alcohol pen to run back and forth over the printhead. Do not drip alcohol onto the print ribbon. Allow a minute or two for alcohol to dry before reclosing the cover.
Posted on Apr 03, 2009
  • 39 Answers
SOURCE: Air bubbles in laminate
Do you have a dual lamination station in your printer? How old is the printer?
There may be contaminates on heated platen that is causing the bubbles. I would go into the printer settings and try various settings such as LAM1-BOTH SIDES and LAM2-NONE then LAM1-NONE LAM2-BOTH SIDES to isolate the issue
Posted on Aug 19, 2009
prashanthcl
  • 460 Answers
SOURCE: will datacard sp75 plus and sp75 run in the same
same driver will work
Posted on Aug 20, 2009
Testimonial: "THANKS DUDE"
SOURCE: heater error in Sp75
tenia el mismo problema, se soluciona verificando que el "ribbon" del laminador este colocado de la manera correcta y la cintilla blanca que tiene pegado uno de los extremos del "ribbon laminador" este pegada al mismo, ya que este funciona como un sensor, si este se despega, la impresora enviara una señal de error y no laminara
Posted on Aug 26, 2009
Datacard sp75 ribbon break
please clean the roller under head
May 31, 2014 | Datacard SP75 Plus Card Printer
Password advanced user diagnostic print tool datacard sp75
The advanced user password for the SP75 Plus diagnostics is 926918
Jul 09, 2012 | Datacard SP75 Plus Card Printer
Error op-01619 lam comm error
In order of likeliness
1. Bad power supply in the printer, in the printer there are 2 power supply's if you have 1 lamination module 3 power supplys if you have 2. 1 power supply may have failed and need to be replaced. You will need to remove the outer covers check for the green light on the power supply. Then check the voltage with a volt meter.
2. Faulty system board. Try a firmware update.
3. If the printer was dropped or bumped hard it could be a loose cable inside.
If all that fails, I would take it in for service.
TulsaBiz.net
or MidWestIdSolutions.com
Jun 03, 2011 | Datacard Group SP75 Color Card Printer
My datacard group SP75 color is printing cards with a white line all across it_
First, try to determine if it is printing a white line, or if an obstruction is possibly scratching the card surface; if it is an actual white line, then you probably have a pixel out in your printhead. Your printhead must be replaced.
Apr 15, 2010 | Datacard Group SP75 Color Card Printer
Datacard SP75 Plus not responding
I have error code h 3 , 7 printer xerox workcenter xd155df
Feb 12, 2010 | Datacard Group SP75 Color Card Printer
Heater error in Sp75
Sounds like either the thermocouple or the heater went out. Was this the error code?
OP-01604 Thermocouple problem in L1 laminator
The comments in the service manual states:
- Check the thermocouple wire for damage.
- If the thermocouple was recently replaced, verify that it is not installed backwards
- Verify that the thermocouple connector is not unplugged or plugged in backwards
I would probably order a replacement part, call in your local DataCard service representitive or send it to DataCard for repair.
Oct 01, 2008 | Datacard Group SP75 Color Card Printer
Datacard Group SP75 Color Card Printer Logo
550 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
