Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
I have a samsung tv model #hln4365w. it turns on but the lamp light blinks and cycles through about 3 times, then the three lights come on including tempature and all shuts down. Is this the sign to replace the bulb?
  • Samsung Master
  • 8,457 Answers
The projection lamp has not been replaced like 1 1/2 or 2 years and tv on and used like 4 or 5 hours a day on this tv?yes,than the projection lamp life is over.Require a new projection lamp.
Posted on Sep 13, 2010
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Picture suddenly went out and the lamp and temp lights in front circle are blinking.
Hi,If your tv is between 2-4 yrs most likely it's time to replace the lamp.If you hear continuous clicking it could be the ballast which is the board that powers the lamp.If you hear buzzing it could be the color wheel,which is a spinning wheel that creates the color on your tv.God bless you!
Oct 13, 2009 | Samsung HLN4365W 43" Rear Projection...
Tv used to make a whining sound when we turned it on, we would turn it off and on a couple of times and then it would be fine. now the tv won't come on at all, it blinks a green light and then shuts down...
Well that humming sound is indeed the color wheel, you say you already replaced it.
The thing is that there are two types of color wheels one with a silver bearing and another one with a gold one, for example if your Tv uses a gold bearing colorwheel and you buy a silver one, it's not going to work, if you still have the orginal colorwheel which i think you did since you replaced it last night, just make sure what color the bearing is. Because the color wheel is the one causing the issues on your TV.
Jun 30, 2009 | Samsung HLN4365W 43" Rear Projection...
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
TV Question??? Samsung HLN4365W
its either the wire connection CN108 on the DMD is loose or the DMD or power supply is defective. I ten d to believe its the connection since it works sporadically. If replugging the connector doesnt solve the problem you may need to do a step by step diagnostics. Do you have the training manual for the samsung DLPs its actually a very easy process to diagnose with the training manual.
Nov 24, 2008 | Televison & Video
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
217 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
