Question about Onkyo TX-SR606 Receiver
My receiver keeps clicking over to standby. This now happens at least every 5 or 10 minutes. I keep powering up again but it continues to click over to STANDBY. Please help.
    Scholar:
  • 150 Answers
Not an expert on this amp But going into standby often means the system's Protection circuit is cutting in to stop an overload condition. As a quick first thing, try disconnecting all speakers and running the unit without speakers for the 10 minute period and see if that helps.
Posted on Sep 16, 2010
Fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Take it out and see if the fan wil turn by hand. It may have somethng obstructing it. The clicking is the motor overload. It wil burn out if it continues to keep clicking.
www.dimplex.co.uk/assets/.../Cadogan_Stove_Instructions_Issue_2.pdf
Jun 29, 2014 | Heating & Cooling
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
ITS ON STANDBY MODE & NOT ABLE TO GET ITS DISPLAY
Try this, not sure if the same would work for ya.
Swich off the amplifier.
Prior to the process check the wires connecting the speakers are not creating a short circuit which is apparently putting the amplified into a standy mode.
1. Press the "A" "B" and power key all at the same time and hold on to it.
2. The amp will go into a reset mode and will keep blinking till it gives a normal "click" sound and the amp turns on.
3. this process would take about 2 - 3 minutes.
4. You may then release the buttons.
5. If it goes into a standby mode again and does not power on, or the standby keeps blinking, get assistance from the engineer.
6. Once it is on, you shall need to do the resetting of alll the configurations done earlier.
Hope it works, it costed me 3k to get the job done.
Nov 12, 2009 | Denon AVR-1603 Receiver
The screen won't turn on. The tv just clicks and
The power board ic coverter it dead.
U need to replace the power board.
U can go the web and buy this board changes
or get the tv repair man replace part and labor $575.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Marantz sr6001 amplifier flashing on standby continuously
hi there
check settings for this configuration ......if you have a subwoofer in the settings, for best overall results choose subwoofer yes, and set main/center/surrround to small....if no subwoofer set left/right speakers to large and small to center, if there is no loe frequency effect (lfe) going to the subwoofer it will go into standby....hope this hlps ....shia
May 28, 2009 | Marantz SR6001
Computer does not stay in hibernation or standby mode
That happen because on the stand by or hibernate setting the time was setting in 5 minutes.
Go to Control Panel >> Display >> Screen Saver >> Power
And set the time right there as your preferences.
Oct 01, 2008 | Toshiba Satellite A135-S2276 Notebook
Dell E178FPf LCD monitor goes to standby and won`t come on again
Check your Power options in Windows.
right click on the desktop. select properties, Gop to the screen saver tab, click on the power button at the bottom right and check to see if its set to turn off or standby the monitor, turn this off.
Keep the screen saver on and set it for like ten minutes.
Also, on the monitor itself, it may have a sleep or power save option set as the default. check all the monitor settings on the actual moniotr itself.
Mar 31, 2008 | Dell E173FP 17" LCD Monitor
Switching on problem Goodmans tvc201t
We had the same television and when it came on after a power cut it just did this clicking thing. We rang up but we were told it would be too expensive to fix. It got chucked.
However, coincidentally, we happened to be given another television of the same model by someone who was moving abroad. The same thing happened when it was unplugged from the mains while on stand-by. Having seen the half-solution above, I tried pressing the on button on the remote but it just kept clicking away. I tried various buttons, including ones on the television itself. Eventually after much button pressing, it made the initial noise like it was about to fire up but then went back into clicking mode. But by keeping on pressing buttons, it seemed to make more and more of an effort to turn on, which eventually it did.
As it happens, the final button pressed was on the remote control, but I think any button will do. So don't give up if your remote doesn't work. Just keep pressing buttons, and it might just gradually build up a head of steam until it turns on. This could take a good few minutes. I've no idea what might have actually happened. Someone posted the same problem elsewhere on the internet and someone suggested it might be something to do with the capacitor.
Jan 15, 2008 | Televison & Video
Lg plasma 50px4d-eb keeps going into standby mode
good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
Sep 27, 2007 | Televison & Video
Onkyo TX-SR606 Receiver Logo
380 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
