Question about Amana AMV4204A Microwave Oven
The microwave started making a strange sound after running for 5 seconds and it is no longer warming things up
LG microwave intermittently runs
I would try troubleshooting the "defrost circuit". The behavior sounds like the microwave is cooking in the defrost mode, where it actively cooks then stops allowing the food to rotate and the heat to spread then actively cooking again.
Nov 06, 2013 | Microwave Ovens
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
My LG microwave Model No MG555F made a loud explossive sound while warming rice gruel and continued to work normally; the incident repeated while I was warming fried fish; the machine continued to wor
The sound you heard was an internal ARC/Short in the Magnetron which creates the microwaves, This is an imminent sign of complete failure, Due to the decrease in prices of new microwaves it is no longer economical to repair them so start looking for a good special on microwaves.
Mar 04, 2012 | Microwave Ovens
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave caused lights to dim, then blew out a power strip
the noise you said sounds like the magnetron or h.v. capacitor or h.v. diode blew up,that could have created a voltage spike,as for the power strip fried, i would have someone check your neutral line in the house power panel, if it open or has a hi resistance spot it will in turn make your homes 120/240volt circuits a voltage divider because of a lack of the neutral wire and can cause problems too
Aug 08, 2009 | Samsung MW5351G Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
GH5184XPB 3 microwave sounds strange when starting
Unplug your microwave. Open the back remove and oil the fan motorand clean the fan or replace the motor.
Dec 19, 2008 | Microwave Ovens
Microwave makes a strange humming noise when it is working - sounds like a vibration of some kind. Does not always happen. Somethings it starts once the microwave has been running for a few seconds. ...
Assuming nothing's loose (such as from past repair attempt) then it may be the magnetron failing.
Your best bet is to keep using but (as always) do not leave it unattended while it's running.
Then if things get worse in some way, that would be a harder failure that can be assessed more easily.
If you are close to the end of the warranty period (1 year parts & labor or 9-year magnetron, e.g.) I would not wait past then.
GE Customer Service is here if you would prefer service now and want to find your nearest GE-authorized servicer.
Oct 14, 2008 | Microwave Ovens
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Amana AMV4204A Microwave Oven Logo
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
