Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
Whirlpool oven doesn't work model gs563lxss
The stove top burners work, but the oven part stopped
working. i unplugged and replugged but that didn't help.
  • 1 more comment
  • varamaria Jun 02, 2008
    thanks for the tip. really appreciate it.
  • Anonymous Jun 27, 2008
    can not adjust oven heat high stays below 260 degrees
  • Anonymous Nov 17, 2008
    we have the same model of stove. What can we do to fix the stove ourselves. Our warranty has run out.
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
Whirlpool gs563lxss oven not working
Have you checked the fuses? If they are good you probably need an element
May 15, 2013 | Stoves Ovens
I have an electric whirlpool range model RF368LXPQ. The stove and oven quit working but the clock still works.The day after it quit working I tried it again and a burner started to work. Once turned off it...
Maybe unplug your power cord from the wall and check the connections on the range. Ranges do not come with power cords attached on them. The installer has to put the cord on, maybe they didn't get the connections tight. While you have the cord unplugged it may be a good idea to check the power at you outlet in the wall and make sure you have 220 volts on it. You will need a volt meter to do this, be real careful not to touch the probes while checking this. Please rate my answer so I get points for it.
Jan 16, 2012 | Whirlpool RF367 Electric Kitchen Range
Stove top won't light?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 08, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Mar 19, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool GS563LXSS - oven won't light. How do you distinguish between issue being a) spark ignitor, b) spark module control board?
After calling to schedule service, thought to try unplugging, wait 10 seconds, replugging to see if it reset anything.
To my amazement, it reset something and the oven started right up. No service call, no parts replaced, working again!
Jan 11, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
964 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
