Question about Samsung Heating & Cooling
I need a english manual for a Samsung Hauzen air conditioner. It is of a type with two split systems, a tower and one high wall with a sigle condenser
  • 81 Answers
SOURCE: Need to know what the icons stand for on remote
Generally all the symbols on each unit are the same. The snowflake does cooling, the sun does heating, the fan does fan only mode, the water droplet does dehumidify and the arrows means automatic mode. The increasing bars refers to the fan speed.
Mat
Posted on Jul 17, 2009
SOURCE: Split System Air conditioner
There normally two types of leakages from the wall unit.
1.The warm air in the room when comes in contact with the cooling coil of heat exchanger (consisting of fine fins where compressed refrigerant evaporates) looses its heat & cannot retain the same moisture content at lower temperature at the point of contact with evaporator. There is a provision of a drain pipe to carry this condensed water to outside water drain. So if the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
2.The second problem can be the leakage of the refrigerant. If there is second type of problem, then there will be very little or no cooling irrespective of continuous running of air conditioner. This can be easily checked by feeling the temperature of outlet air from the air conditioner.
Conclusion-As you have written that there is leakage from the air conditioner, but you have not written whether it is visible or invisible. If the leakage is visible, it is problem number 1 & if it is invisible, it is problem number 2.
If you are not satisfied you are free to ask for more explanations.
Posted on Jan 29, 2008
  • 147 Answers
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
Posted on Apr 05, 2009
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
The system cannot be turned on. Need a tech.
[PDF]Service Manual - Quietside
https://quietside.com/max/.../Service%20Manual_MAX%20Series.pdf
Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.
Sep 28, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
How do I connect my split? the manual is not written in English and the signs on the body of the tower is not in english too.
Refrigeration lines need to be flared & connected. Give 220Volts to the outdoor unit & run the line voltage "comm" wire from the outdoor to the indoor unit, matching lettered post to correct wire. Pull vacuum on refrigeration lines, break the vacuum with refrigerant, and open the outdoor king valves. Start system.
Dec 15, 2013 | Samsung Heating & Cooling
I have a hauzen wall (ducted) fan/air conditioner. how do i use the remote to get cooler air? It is currently on 30 degrees celcius. the remote is in korean and i speak/read english. the remote has an...
i have a hauzen air conditioner. how do i use the remote to get cooler air? It is currently on 30 degrees celcius. the remote is in korean and i speak/read english. the remote has an orange button to turn on and off... can you send me an english manual link? the wall unit is about 3 feet and also has a grey button on the right front bottom unit to turn it on and off. above that on the front right flat side are 5 small round lights that let you know how you have the unit set. hope this description helps you understand what kind of unit i have... i cannot read korean to be more clear. i would appreciate it if you can send a user guide in english. thank you
Jul 24, 2011 | Heating & Cooling
My Samsung is mounted in the wall of my office. Once I turn the air conditioner off,it starts to leak water for several minutes. Any way to stop this? Frank
When the unit is on, go on the back side of the wall where the unit is
mounted. If this is a split system find the condensate hose and make sure it is not plugged and is draining.
If this is a window unit again go in the backside of the wall and see if it
is dripping there. If it is not, take the unit out of the wall, remove the top
and wash underneath the coils. Install the unit so it slants to the back.
Aug 04, 2010 | Samsung Heating & Cooling
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Require specifications for an Emailair split level air con model CWS 034A
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Oct 31, 2009 | Heating & Cooling
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
Heating & Cooling Logo
636 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
