Question about Kenmore 57029 Side by Side Refrigerator
I have a side by side refrigerator and both the fridge and freezer are cool on the bottom, but somewhat warm on the top. I cannot hear fans operating when doors are opened (don't know if I should), and some ice has accumulated on the lower left freezer section.
  • 4,070 Answers
There should be a fan running in the freezer. Hold in the door switch and it will not stop when you open the door. The ice buildup is probably a defrost problem.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model
Posted on Sep 13, 2010
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Freezer working but refrigerator is not cooling
if freezer is close to zero, top to bottom, and fridge is warm(ing), then you likely have a defrost problem, you will notice an abundance of snow/frost on back wall of freezer. it could either be your heater, thermistor, defrost safety thermostat, or your defrost control/main cpu, depending on model. if either or both sides are warm at the top, and cold at bottom, then your freezer fan is out. again depending on your model, it may just be the fan, or a combination fan/main cpu board hope this helps
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold but other is not
In my somewhat limited experience there is usually a fan that blows cold air from the freezer side to the fridge side. I've had that fan go out before and cause this problem. I want to say that it was only like $20 to buy a new fan and put it in.
But yeah, if I'm not mistaken there isn't actually any cooling done on the fridge part of the refrigerator. It's all done on the freezer part. And then there is some sort of thermostat that controls how much cold air is blown from the freezer to the fridge.
Aug 20, 2009 | Maytag Refrigerators
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Nov 09, 2008 | Refrigerators
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Kenmore 57029 Side by Side Refrigerator Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
