Question about Xerox Phaser 8500/DN Printer
Xerox phaser 8500
Prints page after page of rubbish. Can anyone help please?
    President:
  • 2,072 Answers
Most likely your driver is corrupted. I would go to xerox.com and download a newer version and install a new driver.
Power off and power on your printer also.
Posted on May 15, 2008
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Xerox 8500 - overprinting when double-sided
That normally is caused by a dirty maintenance kit. Often times they dry out and do not put enough lubricant on the drum, I would start with a new mainteanace lit., you may also have a bad wiper blade, although thats less likely.
Apr 14, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8500 has error message 37,016.43:35730
the error 37,016.43 is related to the 50V power supply.You can download a service manual here.
The password to open the compressed file is: printer1.blogspot.com
Look at page 3-44 (page 110 in the pdf file) and you will find the steps to troubleshoot the error.
It also contains a parts list in case you have to replace the I/O board.
Fingers crossed and good luck!
Apr 01, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8500 on power up it prints a startup and 89 pages of junk
You cannot turn off the start up page on this machine. The special character pages are called a post script error. You could install a PCL driver for the machine or try changing some settings in the Driver to "RAW". Use the link below for any other questions.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_8500_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_8500_8550):str(8500_8550),question=ref(ProdFamily):str(Prod_8500_8550),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:8500_8550,varset=prodName:%20Phaser%208500/8550
Feb 17, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8500 color issue
In all honesty, I suspect the print head has some bad jets on it.
Xerox will not warrany it since there is the presence of non xerox ink in the print head.
When you have tried as much as you have with the maintenance cycles. I would suspect a bad printhead.
When the jets become blocked to the point where you cant get all the colors sprayed onto the drum, you get mismatched colors.
Apr 07, 2008 | Xerox Phaser 8500/DN Printer
Phaser 8500
you will have to explain more of your problem to give you any feed back
Dec 10, 2007 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 reports Internal Error
I would suspect the elecrtonich module has gone bad.
Without an error tht is my best guess.
Oct 23, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
117 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
