Question about Franklin Industries Refrigerators
I have a Vintage Select 120-bottle wine cooler. It runs and runs, freezing the wine. A local refrigeration repair company has identified the problem as the temperature probe/sensor. They have asked me to buy the part. How much and how do I order?
SOURCE: oster 12 bottle wine cooler
I have the same problem. my oster 12 bottle wine cooler was only six months old. the temp of the cooler won't drop. stay at least 80 F and up. Bestbuy don't even carry this product anymore.
Posted on Sep 07, 2008
  • 19 Answers
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
ramon49
  • 111 Answers
SOURCE: My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Posted on Mar 09, 2009
SOURCE: No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Posted on Apr 19, 2009
N'finity wine cooler
call the repair man if probably needs recharged with freon
Feb 16, 2015 | allavino MWR-1682-BL-C 170 Bottle...
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Woke up one morning to frozen bottles of wine. The Digital Thermostat still said it was at 8 degrees celcius, but was much colder than that.
Most of these types of wine coolers are not brand names and parts are hard to get. If you paid under $200 for it, buy a new one.
Otherwise you will need to have it repaired by a service station or someone who can get the thermostat and or control board, which is very minimal with these coolers.
You can search for parts if you want to DIY. Search for parts using description and make and model.
Good luck.
Nov 19, 2011 | Danby DWC612BLP Wine Cooler
My Hair 12 bottle wine cooler quit cooling. what is the main cause?
Possible bad thermostat. Bypass the thermostat wire to run the compressor. If the compressor start, replace the thermostat. On the other hand if the compressor is running, and there is no cooling; there is a leak and all the refrigerant probably escaped. If it is the case, you need to call serviceman and have him evaluate the wine cooler for possible repairs. P.S. The serviceman may charge a fee for evaluating or estimating the cost of repairs.
Dec 29, 2010 | Haier BC112G Wine Cooler
Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Nov 02, 2009 | Refrigerators
Mar 02, 2009 | Avanti Refrigerators
Haier wine cooler
Dear friend,
ngfam at you service! happy to assist!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 16, 2008 | Haier BC112G Wine Cooler
Refrigerators Logo
551 people viewed this question
Top Franklin Industries Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
