Question about Canon Office Equipment & Supplies
My Canon PC710/PC 730 Flashes an error message E2 10. What does it mean and is the copier too old to be repairable?
SOURCE: Canon np 6012
Getting error code e0 and 07, and flashing, what is that mean.
Posted on Jun 18, 2008
fotobean
  • 103 Answers
SOURCE: On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Posted on Dec 11, 2008
  • 92 Answers
SOURCE: Canon PC 745 error ''8'' plus zigzag. What does it mean?
try to see if there is any paper in the way out of maxine (fixing unit ) or on the right side of the machine you have paper jam thats the signal zigzag
Posted on Dec 30, 2008
goodgold
  • 389 Answers
SOURCE: Getting error code e2 and
U2 this invalid or undue motion scanning device, lamps or copiers panels. It is Necessary to make sure that 2 and 3 mirrors are not bolted screw for transportation, they are found with left side, where the mirrors 2 and 3 stoped . For checking remove glass and try to move the scanning device. Avoid the reason of the stop. If no, search for the fault in sensor, on the left and on the right on движени скарующего device, they can be запылены. opposite event follows to call the service engineer.
Posted on Sep 12, 2009
  • 74 Answers
SOURCE: canon pc710 copier paper feed, no longer grabs the
change or clean the feed pickup roller in the tray unit. To clean it take some alcohol and a cotton rag and clean the rubber roller
Posted on Mar 29, 2010
My Canon PC710 flashes 8
replace drum unit or clean waste toner
Jul 13, 2012 | Canon Office Equipment & Supplies
Canon pc710 copier paper feed, no longer grabs the paper for copying.
Mar 28, 2010 | Canon PC170 Copier
My is not working & shows an error code B200.
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 25, 2010 | Canon Office Equipment & Supplies
My canon mp 730 has an alarm lit and says wrong cartridge. I tried removing print head and cleaning with alcohol...no luck...put in a different cartridge...no luck. What else can I do
On Canon that error means the printhead is bad, nothing to do with the inks. The translation from Japanese to English made the error confusing. You need to buy a new printhead, the part number is on the side of the printhead and starts with QY6-
Jan 31, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
Amber light is blinking, error message when printing
Generally means that you're out of ink in your ink cartridge. Note that the NUMBER of times it flashes is significant: if it's 2 or 3 flashes at a time, then it's a paper problem (jam, out of paper, etc.), otherwise it's an ink problem (replace the cartridge).
Oct 14, 2009 | Canon PIXMA iP1600 Printer
Canon PC-921 copy machine error message "P"
Load paper.If there is paper in the tray,there is a problem with the paper pick up.Try to use the Manual feed try.
Oct 26, 2008 | Canon PC-921 Black and White Copier
Canon MP 730 no black
You can get the MP 730 for Data Bazaar for 120.00 with no shipping charges. Hard to pay 160.00 for a repair when a new one is so much less. Just FYI.
Gina
Apr 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
154 people viewed this question
old marine
old marine
