Question about Nintendo Wii Console
I've wired my wii to my modem. Each time I switch the cable for either the Wii or the PC, internet goes down. Takes me over an hour to fix it. How to avoid this?
I purchased a wireless router because my pc was in one room and the wii in another. No problems with this set up at all. Can use the PC and wii at the same time or at different times.
Posted on Oct 01, 2010
Have connected wii to cable via cisco asa 5505 box. getting error code 52020. have restarted comcast modem to no effect.
Error Code: 52020 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Connecting directly to a modem:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
    Connecting to a router:
  1. Ensure that an Ethernet Cable is running from the WAN or Internet Port on the router to the modem. Power cycle the modem by unplugging it from the electrical outlet, waiting a moment, and then plugging it back in.
  2. Power off the Wii console, and insert the Wii LAN Adapter into one of the USB ports on the back of the Wii console.
  3. Run an ethernet cable from the Wii to a numbered port on the router.
  4. Power on the Wii console, and run a connection test through the Wii console's online settings.
  5. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's settings on your PC:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these as they're listed into the "Manual Setup" of the Wii console's internet connection, except for the IP address. The IP address needs to be different. Add 10 to the IP address and use that number in the Wii console's settings.
you can also visit this site for more information about your comsole tnxx please rate me if this help you...
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52020&system=Wii&locale=en_US
Aug 09, 2011 | Nintendo Wii Console
I'm trying to connect my Wii to the Internet. I currently do not have a wifi connection but I have the adapter that connects to the internet. I have already changed the connection on the Internet...
you can try this step on how to connect your wii console on internet...
if this help you please rate me thank you sir.....
Jul 05, 2011 | Nintendo Wii Console
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
May 05, 2011 | Nintendo Wii Console
How to connect to cable modem
A router is like an internet hub or internet splitter. It lets multiple machines connect to the internet at the same time.
The Wii LAN adapter basically turns your Wii into a wired connection. It's pretty easy to put together. USB goes to USB on Wii. Ethernet cable goes from LAN to router or phone jack.
Jan 04, 2011 | Nintendo Wii Console
How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
    Sep 13, 2010 | Nintendo Wii Console
    How can I connect my alltel internet card to my wii system
    Unfortunately you cannot insert your USB modem into your Wii and have it recognized. Your Wii does not have the ability to operate plug and play devices in the way that your lap top does. The Wii needs to be hooked up to a LAN (local area network) via a wireless G connection from a wireless router or wireless capable modem, or hard wired to a modem or router with an ethernet cable (looks like a big phone wire).
    There is a way to share your lap tops internet connection using an ethernet switch (depending on your operating system). If this is an option that you wish to explore and you have the necessary hardware, re-post asking how to set up a shared internet connection using a computer as a residential gateway. Depending on your operating system this can be done quite easily. You will need a computer with an internet connection (which you have), a 10/100 Ethernet switch, and two Ethernet cables. A switch is relatively inexpensive and the wires are as well.
    I hope that this helps you with your problem.
    Good Luck!
    Jul 28, 2009 | Nintendo Wii Console
    Connection Comcast router to wii
    Error Code: 52021 What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
    Mar 13, 2009 | Nintendo Wii Console
    How do i get connection 24 on my wii?
    When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
    Mar 09, 2009 | Nintendo Wii Console
    Wii wired internet connection problems
    if you have all of these
    Requirements to Connect the Wii Console Online with a Wired Connection In order to connect the Wii console online with a wired connection, you will need the following:
    • A Wii LAN Adapter (where to buy)
    • An active broadband internet connection, such as DSL or Cable.
    • A compatible Internet Service Provider (ISP). Some ISPs require a sign-in every time you connect online, or are otherwise incompatible. Contact your ISP for more information.
    • Either a cable modem or wired router with an available ethernet port. (DSL users: while some DSL modems may be compatible, our experience has shown that many are not. We recommend using a router.)
    • An ethernet cable.
    then go here for more information
    http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wdRouter
    this information was found on nintendo's customer service website
    I hope you find it useful
    Dec 29, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    15 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
